Question about Zenith P60W26 60 in. HD-Ready Plasma Television
Request for solution to repair two 60"Zenith HDTV's PN- P60W26P
Good afternoon, I am searching for a solution(s) to repair two 60"Zenith HDTV's (PN- P60W26P) that will not "power on". There is "no display". One of the two models was pixelated on the left side of the display for some time before it completely died. I am not the actual owner of these units, but work for a company that is under contract to fix them. Any suggestions/solutions you have would be greatly appreciated.
  • Anonymous Feb 16, 2008
    I have the same model(Zenith P60W26) with the same problem , Has power but no display" Please advise
    Thanks
    [email protected]
  • jackf1968 Sep 29, 2008
    i have zenith p60w26 60 inch it will power on and i can hear it but its black screen
Turns on but no display the model # p60w26 same problem
Posted on Mar 26, 2008
I have a unit with the same problem. I spoke to LG Tech support. For this model, there are 2 supply voltages that you need to check off the power supply. You need to make sure that you have VS and VA voltages. I believe they are 75v and 180v. If you do not have this, it could be a power supply problem. If you have those then it is either a Zsus or Ysus problem. The easist way to check is to see if the fuses are blown on the board that distributes the power out to those 2 boards. I am looking for a p60w26 with a cracked panle if anyone is interested. I live in southern california and e-mail is [email protected]
Posted on Mar 12, 2009
SOURCE:
I have a Zenith P60W26P 60" Plasma TV that the sound went out. Any ideas? and yes, I tried the mute
Check the audio settings and make sure that you did not set it to external speakers only.
Jan 14, 2015 | Zenith monitor P60W26P User Manual
Deflection Board Part Number
Call Module Exchange at 972-298-1212
Jan 02, 2008 | Zenith D60WLCD 60" Rear Projection...
My tv zenith is working the only ploblemb is the escreen get blue you see evryting blue de color of the people too
Your problem sounds like the projection bulb is going bad. It is the main problem with projection TV's, and is usually very spendy. I would recommend calling Zenith and request a new bulb.
May 03, 2011 | Zenith D60WLCD 60" Rear Projection...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue escreen
Call LG they bought zenith and there is a class action suit so you can get a replacement or repair refund from LG
Jan 15, 2010 | Zenith D60WLCD 60" Rear Projection...
Zenith P60W26P beeps and won't turn on until next day.
I am having the same problem, beeping and will not come on until the next day....did you find a solution?
Jan 06, 2009 | Zenith P60W26 60 in. HD-Ready Plasma...
Zenith D60WLCD Repair
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
60" zenith tv
Call LG electronics, they bought Zenith and fixed my 60inch Zewnith for free , my model is D60WLCD
Jun 07, 2008 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Discolored picture
Thanks my brother for the tip i will past this on to consumers to be carefull when buying Zenith products.
Apr 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith P60W26 60 in. HD-Ready Plasma Television Logo
407 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
