Question about Garden
Simoniz s1500 My Simoniz S1500 don't stop when I release the gun. Somebody have a solution ?
SOURCE: Simoniz S1400 Electric Pressure Washer
try momarch
Posted on Jul 01, 2008
  • 174 Answers
SOURCE: One day it was working fine the next day
It could be the thermal switch in the motor but that cannot be reset. If you used it with an extension cord, this has blown the thermal reset in the motor. You now have a blue boar anchor. If you haven't used an extension cord then it is probably the bypass valve switch. When you use your washer, then let the trigger shut off, this valve shuts off the motor. When you open the machine, you can tell where this valve is because it somehow has a small switch mechanism attached to it.This valve needs to be pulled out and greased with a good waterproof grease. If you can tell me the serial number, or e-mail it to me at firehead@rogers.com, I may be able to get you a schematic.
Posted on Aug 12, 2009
  • 174 Answers
SOURCE: S1600 Simoniz gun - I took it apart and I have a
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Testimonial: "Thanks - a little frustrating thinking there must be a simple fix - buying a new gun that will also breakdown - that's where they get you. "
SOURCE: Where is the pressure switch located on a simoniz
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Posted on Apr 29, 2010
SOURCE: I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Posted on May 02, 2010
What replacement battery can I get for my simoniz 18vbuf cordless polisher
You can either contact the people that made it and pay an outrageous price, or you can go to a place like batteries plus and buy a replacement that is what I call a re-pop for about half the price of the maker. You'll find a link to them attached
Jun 02, 2014 | Simoniz 18VBUF CORDLESS POLISHER CORDLESS...
Gun leaking when i use my simoniz 1900 pressure washer
The simoniz 1900 gun is very poorly designed. It is held together by a dozen small screws.
First open the gun by taking all the small screws out. No worries, it is much more simpler and worse constructed than a 5-year-old toy gun.
After opening the gun, you will see there are only two parts inside. One at the front connecting to the wand, and one at the back connecting to the hose. The trigger is looped over the joint part.
Make sure the back part is firmly fitted into the slot properly, otherwise it leaks. And be careful don't lose the spring, because there is no object to hold it in place.
Now all you need to do is to put all one dozen small screws back in. Don't over tight the screws, otherwise they will punch through the plastic cover.
Now your simoniz 1900 gun is fixed but it leaves you wonder which 10-year-old designed it?
Jul 30, 2012 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
My water pump is leaking on a Simoniz s1500. Where can I get a new pump?
I am sorry but we have no parts resources, we are a problem and repair site only, that is to say we may help with the installation of the pump but not finding the parts. Have you tired Sears direct? (USA & Canada only)
Apr 06, 2012 | Cars & Trucks
Do you have an instruction book for the finepix S1500
Here's the link for the instruction book/manual for Finepix S1500
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s1500_manual_01.pdf
Hope this helps. Rate if it works. Thanks
Apr 14, 2011 | FUJIFILM S1500 Digital Camera
Mar 31, 2010 | Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
Aug 11, 2009 | Karcher Garden
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
