Question about Garden
Karcher pump oil for G Karcher 2000 QT - Garden
  • 14 Answers
SOURCE: where can i put lubricating oil for karcher jet wash machine
It sounds like you are referring to the oil in the swash plate housing. You can use a multi grade motor oil such as 20w50 or 10w40. Fill to about half way over the swash plate. If the old oil has gone amilky colour, please replace the oil seals first.
Posted on Mar 11, 2009
Testimonial: "post was very helpful and i am going to replace o ring rubber seal where i suspect oil is leaking and also fill it with oil.Thanks very much"
  • 62 Answers
SOURCE: karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
Posted on May 10, 2009
  • 92 Answers
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
Posted on May 22, 2009
  • 174 Answers
SOURCE: My 2200 Gc Karcher pressure washer oil got mixed
If you are talking about the oil in the pump then it should be 10W30 but must be NON DETERGENT. Remember the reservoir should only be 1/3 full
Posted on Aug 09, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
Oil use in karcher 2.900m pump.?
30 weight non-detergent motor oil
May 24, 2014 | Karcher PUMP OIL CAP G 1/2
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
you need to know where oil is coming from. pump or motor? both will use normal motor oil
Mar 30, 2014 | Karcher Garden
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
Mar 15, 2014 | Karcher Garden
2700 psi pressure washer oil capacity in pump
is there a nut with like a glass insert in it thats your oil leavel
Jul 13, 2011 | Karcher FactoryReconditioned 2000 PSI 20...
I WOULD LIKE TO KNOW, WHAT OIL TO USE FOR ANY KARCHER PUMP. Thanks. Richard V. Tucker
This depends on the brand of pump that you have, there are many different pump oils out there, getting the correct one is essential to increase the life of your pump.
Oct 06, 2010 | Karcher 2500 PSI Pressure Washer
Need to know what oil to use for oil change in the kracher by honda
engine oil....10-30...sh/sj.......19.52 oz do not over fill
oil in pump is a special oil through karcher....3.52 oz of pump oil
Jul 15, 2010 | Karcher 2500 PSI Pressure Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
How to put oil back into the Karcher water pump
You need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out.) CAUTION: there is some spring tension on the brass head.
Take the brass head off and set to the side on a rag or in a bucket. Dump out whatever oil is in the oil side, making sure not to drop the swash plate or bearing (the pieces sitting in the oil). Fill the oil end with aproximatly 4.5 ounces of Karcher pump oil, (or just 20w 50 weight non-detergent oil). Put the brass head back on and tighten bolts. Put the pump back on the machine.
If this helps please rate.
Bill
Jan 22, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
