Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Model GSL 25J FTA BS - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Sharp instruction manuals
Contact Sharp customer service on the web..Sharp website...give them the model number you gave us.
Sep 04, 2014 | Sharp 25J-M100 TV
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is an fta lock
FTA means "Free to Air"
It mostly means your unit can't do decoding of encrypted channels, and is locked to FTA.
It may also be if your unit was sold by a specific provider that is is locked to their own channels.
Feb 28, 2010 | Televison & Video
Freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
May 03, 2009 | Refrigerators
Need two trays for sharp sj-25j-wh
go to sears .com,click on parts,put in your model number get your part,cross check the price at repair clinic .com-mike
Nov 11, 2008 | Refrigerators
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Jul 15, 2008 | Sharp 25J-M100 TV
Earphone
hi there, some tv model have the option for earphones, others don't, ty
Dec 29, 2007 | Sharp 25J-M100 TV
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
