Question about Vizio L32 32 in. LCD HDTV
Television Powers Off While Watching
...it then turns right bcak on if we hit the power button (or stays off if we do no). Happens randomly. It can stay on for hours and not turn off or be on for 5 minutes and turn off. As you can imagine, it's frustrating. Vizio support not helpful as I'm not under warranty. No other problems with this 1.5 year old set. Thank you for any insight. B
  • 5 more comments
  • Alcya25 Nov 08, 2007
    My 32" LCD Vizio set turns off on its own while watching a movie or show then pops back on again very annoying.
  • fn2ride Mar 26, 2008
    My 42" Vizio plasma was doing the same thing, powering off when it felt like it. Now it has quit except for the orange light in the lower R.H. corner.
    If I unplug and replug it in, it clicks twice but no function. Any ideas?
  • liqrdic May 21, 2008
    Brand new 42" Vizio right out of box turns off randomly, when I keep turning it back on the intervals that it stays on get shorter and shorter. Is it possibly getting to hot and shutting itself off? EXTREMELY annoying.
  • db37 May 27, 2008
    My Tv Is a vizio LCD/HDTV 40 inch #L37hdtv10a, TV started with square
    pixel freeze , then electricions replaced home fuse panel and the TV
    now has sound but no picture, Is there any one who repairs
    curcuit boards?? and if so which one.
  • Steve in KY May 31, 2008
    My Vizio 32" LCD tv started turning off on its own, then would come back on by itself after about 30 seconds. Now it will not power up at all.
    Does anyone know what the fix is for this?
  • wmslawyer Jun 02, 2008
    my vizio L32 continually powered off while wacthing then always came back on. It was just a nuisance at first but now it will not come on at all. Is this a problem that is fixable . I note that many people seem to be having the identical problem. Should I just rhow this TV int he garbage or is it worth fixing and how to I accomplish the fix.
  • dconner77 Aug 04, 2008
    Same with mine. Just turns itself off and then back on in 30 sec. Now it won't power up at all. Is it the power supply? Where is the switching done? No browning on board or cold solder joints visible.
    Problem Solver:
  • 7 Answers
I found a very good web site for protron Television problem.
Try out now . . .
http://www.ProtronTelevisionSolution.com
for find a best solution.
Posted on Jun 26, 2009
While we are watching the television it just blacks out ,but we can still here it ,but if we turn it off then back on again it works then it happen a few min later
Posted on May 03, 2009
Thanks to all! I got a new board and am back up and running.
Posted on Sep 21, 2007
My L32 HDTV10A was doing the same thing, and finally stopped coming on altogether. I got to Level II vizio Support thinking it was the Power Supply board, but the guy there told me this problem is usually the Main Board. Vance Baldwin is the electronics parts distributor for Vizio. Try website http://www.vancebaldwin.com/ or call them with your model and serial number at 800-432-8542. Mainboard about $150 Power Supply Board about $50
Need a new schematic for this vizio L32HDTV, that blew power supply board. The problem started with black squares on the TV, followed by the TV powering off, prior to the TV sparking days later.
Posted on Sep 18, 2007
    Genius:
  • 1,153 Answers
Possibly set was droped at sometime are just hit hard. Maybe loose connection in powersupply
Posted on Aug 14, 2007
SOURCE:
TV power light is red when off after I hit power
The power supply board has a problem. Replacements can be had at the shopjimmy web page.
Oct 20, 2014 | Televison & Video
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Zenith tv, trouble turning on and staying on
There is a problem in electrolytic capacitors, probably the 300V one in the primary section of the power supply.
You should measure if there is a stable 300 V available in the primairy section...
Jul 07, 2009 | RCA F27450 27" TV
4wd turns on and stays on
HAVE THE SWITCH CHECKED OUT
Jun 08, 2009 | 2004 Suzuki XL-7
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
Maytag 5500 AWW Turns off randomly shortly after starting
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt electronic components. If you have either... then you will need the the new motor conversion kit which includes the new motor, new motor control board and the wire harness. What you describe are signs the motor control board is nearing its end of life...
The kit takes about an hour to install. See www.neptunewaxmotor.com for disassembly photos so you can inspect the motor control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Vizio L32 32 in. LCD HDTV Logo
1,136 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
