Question about Akai LCT3785TA 37 in. LCD HDTV
Akai blinking light red and does not turn on
How can i fix my lcd, what is the problem?
  • 2318 Answers
SOURCE: Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 26, 2008
  • 21 Answers
SOURCE: TV ON STANDBY MODE
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3701AD POWER SUPPLY BOARD MLT386X
Posted on Dec 30, 2008
  • 12 Answers
SOURCE: AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Posted on Sep 06, 2009
  • 13 Answers
SOURCE: T.v. won't turn on
The following parts can be purchased at digikey.com or mouser.com web site. I am also posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit (may cause the red light blink problem, but also see below).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on I found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Posted on Oct 04, 2009
  • 2318 Answers
SOURCE: MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Posted on Mar 17, 2010
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
I unplugg my Akai Tv, and the red light blinks. I plugg it back in and it still will not turn on. After many attempts it finally turns on.
I can assist you to fix your unit yourself, time will come your unit will not even power up if the faulty parts is not isolated. It will not cost you much for parts... I'm online now at the pay question, click it here.
Jdvillanueva
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Feb 28, 2010 | Akai LCT2701TD Television
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT3785TA 37 in. LCD HDTV Logo
13 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
