How do you get inside the washer to replace parts?
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
SOURCE: Whirlpool Thin Twin Washer - does not drain water.
MAKE SURE THE CONNECTION ON THE TOP PANEL FOR THE LID SWITCH IS GOOD. ON OCCASION WHEN THE TOP PANEL IS SLID BACK IT CAN BEND THE BRACKET THAT HOLDS THE FEMALE END ON THE CONNECTION. HOPE THIS HELPS
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
SOURCE: I need a model number
Hi
Whirlpool currently have two models under production-- LTG5243DQ & LTE5243DQ. You can check out these models at this link--
Whirlpool Washer/Dryer Stacked Combo Models
If you have a different washer model then check out the model# at these locations---
Hope this helps... Please post back if you need more information.
Daniel
