SOURCE: sometimes Pc restarts
Typically due to a bad driver, or faulty or incompatible 3rd party hardware or software
1. when & how did this problem start?
2. Did you try adding any new third party hardware or software
(This could be anything a PCI card, a new video driver, windows update, a 3rd party wireless card
3. Try a System Restore
4. Remove all PCI cards, uninstall all 3rd party H/W and S/W
5. Try reinstalling all the drivers in the right order
6. Run diags on Memory
7. Repair the os
8. If all these fails, you could suspected memory
SOURCE: sometimes pc restarts
may have been a filesystem problem...do one thing. if you have the winxp cd..boot in recovery console.
refer here for info on how to run reconvery console.
in the console command, type chkdsk /r, like this
c:WINNTchkdsk /r
let it run until finish...do this several times, at least 2 or 3 times. then restart your PC again.
if you don't have the winxp CD, but still can go to windows. try running the check disk using command line.
START >> RUN >> type cmd
in the command console type chkdsk /r then press Y......restart your PC.
let us know if you need more info.
SOURCE: i getting error code in system log after automatic restart.
Hello there,I suggest you to save all your important files, andfind your bootable disk for winxpthen reformat it
the problem may cause of a virus,trojan or worm that infect with your operating system starts up...
