SOURCE: Yard-man model 12a-979L401 won't start (9 years old)
My dad always taught me, rest his soul, that basic 101, if you have gas getting to spark, SOMETHING out to happen.
I'll ask a series of questions and propose some possible solutions. Hopefully we'll crack this mystery. Warning, this might be a tad lengthy... ha
1. Is the spark plug firing?
To check the coil that sends spark to your spark plug and the plug itself:
You can remove the spark plug from your engine and reconnect it to the spark plug wire while it just lays on your mower. pull the starter rope (make sure you're holding down the kill lever on the handle). Look at your plug end as you pull the rope.
Got spark? If yes, go to the next step, flagged ***. If no, look at the end of your spark plug that would go into the engine. The "L" shaped finger should be gapped from the small circular shape on the plug... this is the "gap". Your manual may provide specs on how wide this gap should be. If there is no gap, your plug won't work properly. The "L" shape is a soft metal and can be bent... create the proper gap. Try the test again to see if the plug is sparking. If not, you may have an issue with your coil.
***Yes to spark. Let's look at the gas issue now. OPTION 1. I will tell you that in my experience, water in gas is a major culprit for a mower not running. You've replaced all the filters... good.
I'm not sure of your mower, but most models have a "bowl" bolted to the bottom of the carburator. Sometimes moisture can get in the gas, get trapped in the bowl and won't go away or won't allow gas to get to the spark. Loosen the bolt... it's ok if gas from the bowl spills from this, the bowl doesn't hold much gas and it won't drain your tank. Plus, this means your carbuator is allowing the gas from the tank to the bowl. As you are looking at the gas spilled on the mower deck, see if there are beads of water in it. As you know, water and gas doesn't mix. This would be a tell tale of the problem. I would carefully remove the bowl from the carb and wipe it dry, then reassemble the bowl.
To be on the for sure side that you have no more water in your system, you could disconnect your fuel line from the gas tank and drain it out. Use a jar or container... you can see water in the bottom of it. You can reuse the gas too... just don't include the water!
OPTION 2. If your carb and tank are now H2O free and you're still getting to results, you may have a clogged jet on your carburator. This little pin-hole passage allows gas to pass through to the spark. Sometimes a mower sitting up a while, can cause a laquer effect to gas and it can block this passage. Removal of the carburator from the engine is required and a simple pin can be pushed through this passage to knock a "plug" out.
Geez I hope I didn't miss anything! ha
Good luck to you... I hope it's a quick and easy fix.
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
SOURCE: My lawn push mower will
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
SOURCE: lawn mower runs rough.got fresh gas,new spark
Hi fcruz775
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
