Question about Dishwashers
Kenmore 665.1389 No power, lights won't come on. Tried circuit breaker didn't help. Is there a fuse or probably the control panel?
  • 131 Answers
SOURCE: no lights on the control panel
check the thermal fuse at the control panel, the door switch, or the electronic control.
Posted on Mar 10, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
  • 188 Answers
SOURCE: power to dishwasher but no power to panel
Open your console and check the continuity of the thermal fuse (clipped to the electronic control unit [ECU]).
Post your model number if you're still having problems and I'll try to assist you further.
Posted on Apr 04, 2009
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
No power to my kenmore dishwasher
check the power circuit to the washer
Dec 21, 2013 | Kenmore Kitchen Ranges
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I tripped a circuit breaker but a reset didn't resolve power to the outlets. I replaced cgi outlet hoping that would resolve the issue but it didn't. What is the problem and/or issue? Can&#
I believe you are referring to a GFCI receptacle. Did
you have power at the GFCI Location? If so, make sure
you wire the line and load portion of the GFCI unit properly.
Jul 31, 2012 | Electrical Supplies
Dryer not heating
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Thanks.
May 16, 2012 | Kenmore Dryers
My LG DLE 5932w CONTROL PANEL WON'T LIGHT UP AND THE DRYER ONLY BLOWS COLD AIR. COULT THIS BE A BAD FUSE?
Check the 220 volt circuit breaker or cycle it. If on the other hand you have fuses instead of breaker panel, with 220 volt you should have two fuses to contend with and one or both may be blown.
Nov 18, 2011 | LG Dryers
Bike ran great all day. Turned it off but when I went to restart, no power at all. replaced ignition switch. short in system somewhere but can't locate it. Start button kind of clicking like it...
You didn't say what year or model bike you're working on. The clicking you're hearing could be a circuit breaker tripping. If it's a soft click like a turn signal flasher clicking, this is probably a circuit breaker or a relay. If it's a loud click, it may be the solenoid on your starter. Does anything else on the bike work? If not, it's probably the main circuit breaker. How about any security system that may be on the bike?
Good Luck
Steve
Aug 06, 2011 | Harley Davidson FLSTC Heritage Softail...
I have a kenmore model 665.13592k600 dishwasher and it won't turn on. Nothing at all works. Any suggestions?
Assuming you have tried to check the mains power circuit breaker/ fuse is still in tact, the most likely cause is the heat fuse tripping. This is located inside the control panel.
See item 18 on this diagram.
Hope this helps.
Jul 07, 2011 | Kenmore Dishwashers
Fuse location for power windows 2003 Buick Century
There really isn't a fuse for just the power windows and if a fuse was blown that did control the power windows pretty much everything that the body control module works would not work so i believe what you would be looking for is the circuit breaker for the power windows. That circuit breaker is located in the instrument panel fuse block . You need to open the passenger door to see the fuse panel cover. Anyhow I don't have a picture but the circuit breaker is on the top row second one over from the left. I hope this helps and good luck.
May 17, 2011 | Buick Century Cars & Trucks
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
