Question about Motorola Mobility E815
My phone is all out of whack
At first my phone would turn on after i took out the battery and asked em to reset the time and date. Then it would go to the home screen and say 60 min in the center and network unavaliable, and it would search for one fore a few seconds then just stop. I cant charge or do anything i need help fast plllllllease
  • 94 Answers
Well maybe your sim has been cancelled or blocked or even out of date , thats what hapened to mine ( one of them lol ) so you can order free sim cards of all kinds on the internet i suggest you do that 1st and then your network should be fully functioning , after that try reset your factory settings which can be accessed via the settings icon , then select restore factory settings the code should be 1234 or 12345 , that should fix your date problem , and for your charging problem try a new battery becoz if your battery was removed and then when u put it back in it doesnt charge then there must be a fault with your battery , hope i helped :D
Posted on Oct 21, 2007
6ya staff
SOURCE:
How do I change the time on my lgl34c
go to settings and select date and time.turn off automatic date and time and set the date and time to what you wish
Sep 27, 2014 | Cell Phones
HOW TO SET THE TIME AND DATE ON THIS PHONE
time and date should automaticaly reset but if it doesnt try this. With the phone turned on remove the battery for about 30 to 60 sec. then put battery back in and turn phone on it should have reset the time and date. Doing this worked on my wifes phone hopefully it will work 4 yours.
Jul 14, 2011 | Cell Phones
Asks to reset date and time evertime I turn it on
Hi there.
Yes there is a soloution to your problem, there is an internal lithium battery insider the camera that keeps the time and date, its this battery that needs to be changed.
Good luck and thanks for using FixYa!!
May 12, 2009 | Nikon COOLPIX S710 Digital Camera
WONT HOLD DATE/TIME, KEEPS REQUESTING TO RESET!
Hi there, been playing around trying to get camera going,as i took apart (easy enough, if you can handle a watch repair screwdriver) what i did find seems to be a standard watch battery located bottom left next to speaker. Pretty sure if you replace this, it should solve your problem. Just be carefull when taking out ribbon cable!
Cheers Greg.
Apr 24, 2009 | Sony Cybershot DSC-T200 Digital Camera
Time and date
reflash the phone to correct this issue
MABWIZ - replaced the lcd or flexcable
Sep 27, 2008 | Motorola Mobility RAZR V3
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
Blackberry Pearl, JVM Error 547
IF YOU HAVE A COMPANY PHONE - CALL TECH SUPPORT
IF ITS A PERSONAL PHONE CALL YOUR PHONE SERVICE PROVIDER ask if there is any special version of software you have to use.
try a hard reset (take the battery out wait 2 mins then put it back in) if that doesnt work...
BEFORE ANYTHING !!!! use the desktop software to backup your data (because you will be erasing ALL DATE on the device) on the BB (if you can) and save the file to the desktop. next go to https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4you need to download (use pull down menu)blackberry desktop software 4.6 and the blackberry devicesoftware (FOR YOUR MODEL PHONE) install the desktop software first thenthe device software.. this can take maybe an hour (not including thedownload time) once your done use your desktop software to restore yourdata
GOOD LUCK - Please rate this solution :]
Jun 06, 2008 | RIM BlackBerry Pearl 8100
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Motorola Mobility E815 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
