Question about Avanti Refrigerators
Avanti wc600cl Display flashes e1
2 Suggested Answers
jigeo
  • 57 Answers
SOURCE: wine cooler avanti model wcr683dzd,display
Wine Chiller does not operate.
1. Not plugged in.
2. The appliance is turned off.
3. The circuit breaker tripped or a blown fu se.
If the character E1 appears on the digital display call service assistance.
Avanti Customer Service
800-220-5570
Posted on Apr 25, 2008
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
I purchased a avanti 380 treadmill from eBay. Was running perfect so we put it in our trailer and brought it home. When we plugged it in it had LJE1 displayed in the time display and flashes 68 in th
Adjust the REED switch, see the diagram, clean it, tight the connector very well
2) replace the battery well, clean the contacts, retight the spring contacts with pliers very well.
and proof again. God bless you
Sep 06, 2012 | Avanti Fitness AT380 Treadmill
I have a Avanti 380 when it is turned on LJE1 is displayed in the display and the number 68 flashes in the MPH display
adjust the REED switch, clean it, tight the connector very well.
see the diagram
2) replace battery, clean the contacts batteries, retight the springs contacts batteries, and clean it.
Proof again. try to RUN after you did the steps before, the software diagnostic, for troubleshooting, and fix it.
God bless you
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
E1 code on kenmore front load dryer
Hello there
I have written a list of codes that should cover your problem nd give you some idea what to check ok
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
80 degrees F. - 9.2K ohms. E3 Touchpad or Software mismatch Flashes when there is a touchpad or software
Dec 16, 2009 | Kenmore Dryers
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Nov 23, 2009 | Cell Phones
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
Refrigerators Logo
22 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
