Question about Garmin Color Fishfinder 160c
Why won't my display come on on the 160c. The screen stays dark when i hit the power button
All buttons illuminate when i press the power button and go off when i release it. No light or display comes on the screen. What could be causing this to occur?
4 Suggested Answers
SOURCE: Will not turn on
When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to hold the power button the screen will continue to pixelate dark and then go blank. In the end, the device still will not turn on.
Posted on Aug 01, 2008
eradiostore
  • 1654 Answers
SOURCE: Unit will not stay on. With new batteries
If using rechargeable batteries, your batteries are not getting charged. Check your charger, battery contacts and batteries. Clean contacts with a pencil eraser.
If using alkaline batteries, check placement of the batteries to be certain they are in the correct way, and also, clean the battery contacts.
Posted on Sep 08, 2009
bronk50
  • 27725 Answers
SOURCE: Turn on, Garmin screen comes on, then a screen showing press dot comes up and won't go any farther
does it still happen when plugged into a computer ?
might be a problem with the battery
or it might be a lead connection problem if you are tech minded there are youtube video's that show you how to replace garmin batteries and to dismantle garmins
not sure if this garmin is the right one
http://www.youtube.com/watch?v=zVwMHpNIVjQ
hope this helps
Posted on Oct 03, 2012
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Sep 10, 2017 | Tablets & eReaders
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
My gateway 450rog computer screen wont come on after i press the power button why
Make sure the machine has power.
The battery might be dead, so connect your notebook to the AC power adapter and plug the adapter into a working AC outlet.
If you have a power strip or surge protector, make sure it is on.
If you are having trouble with battery power, recharge it if it has been fully discharged or replace it if necessary.
Check to make sure the computer is not in "sleep" or "hibernate" mode.
Press a key or the touchpad and wait for it to respond.
Try pressing the power button.
Make sure that you fully engage the power button.
You should press and hold the button for at least half a second but no more than three seconds for the machine to power on.
Adjust the screen's display brightness because it may be too dark. Press and hold the "FN" key and press the key with the icon to increase brightness.
This icon looks like an "up" arrow and a picture of the sun.
hope this helps
Sep 13, 2012 | Gateway 450ROG Notebook
How do i reset my i-pad?
Hold down the power button and the home button for 10 seconds
Dec 12, 2011 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
JVC KD-AVX1. The head unit will not "turn on" when the power button is pushed. The display just stays off. The face lights up when you press the eject button and opens up and you are able to feed...
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
May 09, 2011 | JVC KD-AVX1 Car DVD Player
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
Battery on my HTC s710 lasts for 3-4 hours
if you momentarily push the "start" button, that should put the phone into hybernation. Which means the screen will go dark and quit using power. If the phone rings it will automatically wake up. If you want to use it just hit the start button again.
There are also some settings in the "settings" menu that determine when and for how long the screen stays illuminated when not in use.
Jul 07, 2009 | HTC S710 Smartphone
Garmin Color Fishfinder 160c Logo
35 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
