Question about Garmin Color Fishfinder 160c
No display on garmin fishfinder 160C why
Display will not come on. Theres power to the unit. The buttons illuminate when impress the power button but go off when I release. No light appears on the screen
Editor925
  • 285 Answers
SOURCE: To wireup 160c Garmin fishfinder, there are seven
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Posted on Jun 15, 2009
budgie140
  • 502 Answers
SOURCE: Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Posted on Jul 08, 2010
  • 15 Answers
SOURCE: GARMIN 60CX Contour Map display: Sent maps to
The topo maps are low in the map hierarchy. If another mapset is loaded at the same time and is also checked it will likely "cover" topo. I think the Recreation maps are the only one's lower in the hierarchy.
Posted on Jul 21, 2010
justinbur167
  • 257 Answers
SOURCE: the boat has been idle
Hello Alexpreerado,
I understand that you are having a problem with your Garmin fishfinder 300C. When in the water the unit is not turning on, however when out of the water the unit will turn on. I want to see if the unit will work in simulation mode.
To do this you will need to follow these directions:
When powered on select CONFIGURE, SYSTEM, SIMULATOR, ON.
If the simulator works then you know that the unit is working. Then go back thru the same way and turn the simulator back off,
Your unit is equipped with a self diagnostic unit that if there is a problem it should power and give you a fault reading. If the unit is not powering on while in the water you are loosing power to the unit. Put the boat back in the water and check the voltage going in to the unit. You may find that you have a short while the boat is in the water.
Post back with what you find from the above possible solution to the problem. And I will give you some more possible problems and solution to your problem.
Thank you for choosing FIxYa.com
Justinbur167
Posted on May 27, 2011
  • 910 Answers
SOURCE: Recently borrowed garmin 90
I think the water you're working is a little shallow and that's why you're not getting the response you'd expect.
You can have the Depth Range as Auto which automatically tracks the bottom or set if anywhere between 5 and 600 feet.
You can also set the Scroll Speed as Ultra, Fast, Medium, Slow & Paused so it depends what the owner has it set to as to how quickly it will respond to movement.
Posted on Jun 10, 2011
2010 rod king flash codes
2011 TOURING ODOMETER SELF-DIAGNOSTICS
Press and hold the trip odometer reset switch while turning the IGN ON to enter diagnostic mode, release the trip odometer reset button and "diag" will appear on the odometer display. However if "no rsp" appears instead then you either do not have the RUN/STOP button in the ON position or if it appears after the PSSPtbhas appeared then the particular module that "no rsp" is displacing is not present on the motorcycle. THEN press and release the trip odometer reset button again and "PSSPtb" will appear on the odometer display, the letters "PSSPtb" refer to the different modules that could display codes if the motorcycle is equipped with those modules. "P" indicates ECM codes; "S" indicates TSM/TSSM/HFSM codes; 'SP" indicates Speedometer codes; "t" indicates Tachometer codes; and "b" indicates ABS codes. If you rapidly press and release the trip odometer reset button you can cycle through all of these letter(s) one by one and they will flash as you do so. Once a letter is flashing its corresponding module has been selected to show codes on the odometer display. When a letter is displayed and flashing if you press and hold the trip odometer reset button, if there are no stored DTC's"none" will appear on the display. If any DTCs are stored in the module, whether current or historic, they will be displayed on the odometer. If you the rapidly press and release the trip odometer reset button you can cycle through all of the stored DTCs. If "no rsp" is displayed move on to the next module and when you get to the last module the display will show "end". If you want to clear all DTCs for any module press and hold the trip odometer reset button and they will all be erased from the computer memory. If at the end of a display of DTCs you want to progress to the next step or sequence for that module, quickly pressing the odometer reset button will cause the module part number to be displayed. After that display if you again quickly press and release the trip odometer reset button the display will move on to the next module display in the sequence of modules. When you are finished and wish to exit the diagnostic mode simply switch off the ignition or run switch.
continue to the next module.
If you want to do a quick of instrument function, a "WOW" test can be performed by entering the odometer self-diagnostics. In this test the background lighting should illuminate, the gauge needles should sweep their full range of motion, and the indicator lights that are controlled by the serial data circuit (the battery, the security and the check engine) should illuminate. If the instrument fails "WOW" test, check for a poor battery condition or connections and/or a poor ground connection condition and check for proper ignition voltage to the instrument. If any feature in the speedometer or tachometer is non-functional, you will have to check further into that/those area(s).
Observing the check engine lamp is the best way to start to diagnose ECM system problems. "IGN ON" means that the ignition switch is turned to IGN and the engine run/stop switch is set to RUN (even if the engine is not running). When the IGN is turned ON, the check engine lamp will illuminate for approximately four seconds and then turn Off again. If the check engine lamp is not illuminated at IGN ON or if it fails to turn off after the initial four-second period, then you must check for a no ECM Power situation.. After the check engine lamp turns off following the first four second illumination period, one of three events may occur. Which are i) The lamp remains off which indicates there are no current fault conditions or stored DTCs presently being detected by the ECM; ii) if the lamp stays off for only four seconds and then comes back on for an eight second period it is an indication that a DTC is stored, but no current DTC exists; iii) if the lamp comes on and remains on past the eight-second period it is an indication that a current DTC is in existence.
Jun 08, 2014 | 2011 Harley Davidson FLHRC Road King...
Tip
Oldsmobile service light 1991-01
Alero
2000-01
Turn the ignition to the ON position, engine OFF. Press the RESET button and release. The CHANGE OIL indicator will start flashing
2000: Press and release the RESET button again.
1999: Press and hold the RESET button until an audible chime is heard and then release the button.
Intrigue
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the key off after the the light has finished flashing, then start the vehicle. If the CHANGE OIL SOON indictor comes back on, the engine oil life monitor has not reset. Repeat the procedure again. If the vehicle is equipped with the U20 option code, the vehicle as an oil life low indicator. The oil life low indicator shows an estimate of the oil's remaining useful life. When the oil life index is less than 10 percent, the display will show OIL LIFE LOW. To reset the oil life monitor, press and hold the MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to 99 percent.
Alero,
Intrigue,
Cutlass Supreme
1999,
1998,
1996-9
To reset the "CHANGE OIL" light, turn the ignition switch to the "RUN" position with the engine off. Fully depress and release the accelerator pedal three times in five seconds. The light will flash twice and go out.
Aurora
1995-99
To reset the "OIL LIFE" message, press the "ENG" button with the ignition on until "OIL LIFE PERCENTAGE" is shown. Press the "RESET" button for 5 seconds. "RESET" will appear and then "OIL LIFE" will show 100%
Eighty-Eight,
Ninety-Eight,
Regency
1994-97
When "CHANGE OIL NOW" is displayed, press the "RESET" button. Press "SEL" to display "OIL". Press "SEL" to display oil life. Press and hold "RESET" for 5 seconds. A "RESET" message should display with oil life changed to 100%.
Eighty-Eight,
Ninety-Eight
1992-93,
1991-93
Press and release the "TEST" button on the Driver Information Center. This will illuminate "CHANGE OIL NOW" if it is not already illuminated. Press and release the "OIL" or "OIL INDEX" button. Next, press the "RESET" button and hold for at least 7 seconds.
Toronado,
Trofeo
w/o CRT Display
1991
To reset "OIL LIFE INDEX", press the "2 OPTIONS" button: three times if the vehicle is equipped with a phone and compass, once if equipped with neither. While "OIL LIFE INDEX" is displayed, press and hold the "RESET/ENTER" key at the bottom right of the 15 button switch for 5 seconds.
on Dec 07, 2009 | Oldsmobile Alero Cars & Trucks
0xc19a0002
Switch on your printer.
Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special Key Combo
Press and releasethe key in sequence 1, 2 and 3 buttons.
display says "support" R0631M
Press and release the right arrow button until the display says " System Configuration Menu".
OK button.
Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status
Press and release the OK button.
Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page..
Oct 10, 2013 | HP Photosmart C6280 Printer
How to reset service light on a holden astra 2004
theres a push button to the right of the clocks.... press and hold the button. switch ign on. the letters insp appear for 2 seconds. keep holding button in until blank appears in the display. then release button and switch off ign..... job done. its the one for astra in uk but cant see it being different. please leave a comment and thumbs up
Dec 22, 2011 | Cars & Trucks
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
INK SYSTEM HAS FAILED. ERROR 0XC180201
Perform the steps given below to resolve the issue. Make sure that you perform the steps once in a Printer Lifetime. And the resolution will be in two parts. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Oxc18a001
1. Get the unit into the ?Support Menu? by following the steps below. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
May 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
0XC18A0101
May 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0101
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Apr 21, 2010 | Office Equipment & Supplies
Garmin Color Fishfinder 160c Logo
73 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
