Question about Smeg Kitchen Ranges
How to remove filter cover for cleaning? Rangehood is hidden behind a pullout cupboard door.
  • 726 Answers
SOURCE: Head Light cover
lift your bonnet up
see if there are any screws possible no
it should clip on
then just pull off and put on same way it should be like a long bent clip up top the actual cover
Posted on Jul 29, 2008
  • 4 Answers
SOURCE: How do I remove the cover from the Viewsonic
I was equally frustrated by this, but eventually figured it out. There are two finger-sized slots on the bottom of the panel covering the monitor's connections. Push them in (towards the top of the monitor) and lift the cover away from the back of the monitor.
Good luck,
-Brad
Posted on Jan 08, 2010
Beelz
  • 666 Answers
SOURCE: Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Posted on Apr 23, 2010
  • 2976 Answers
SOURCE: I want to clean the filters on my Baumatic
The metal filters can be cleaned with ANY good degreaser. The carbon filters need to be replaced. Parts are available from the manufacturer or an appliance repair shop that handles your brand.
Posted on May 02, 2010
  • 11800 Answers
SOURCE: We are about to get
It's better to get a 900 mm wide one simply because it will have to run at a lower speed to get the same suction effect. And imagine that you will have even the slightest air current in there - the fumes will be blow away from the hood a lot easier on the 700mm one.
Posted on Feb 16, 2011
Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
Hi, my dryer has 3 things to check out of which one is more hidden:
- empty the water reservoir
- clean filter in the door
- clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
Did you check all 3?
Hope this helps
Mar 25, 2016 | Hotpoint Dryers
How do i open air conditioner to clean filters
A wall unit, split system can be tricky to get. Some filters slip out, some are behind a cover held in by screws, others the complete plastic needs be removed. The filter would be in the section where the air enters the air con.
Other units have the filter behind the return air grill, others a door needs be removed to access the filter rack
May 08, 2015 | Heating & Cooling
Where are the circuit breakers
Look behind all cupboard doors higher and lower. Also look for a brown plastic cover in face of cupboards as well. Usually closer to where power cord enters from outside.
May 04, 2014 | Forest River 2010 Rockwood Mini Lite 2304
Replace the door lock switch on 2009 lincoln towncar
Use pry bars to remove door panel. Remove screws on door panel look for hidden screws behind small plastic covers. Then disconnect switch and install new one
Mar 26, 2014 | Vehicle Parts & Accessories
Hi, I am installing a DHI645KAU I think it is. It is an under the cupboard slide our 60cm range anyway. It is going into a new kitchen. The electrician said I had to cut the lead off and run a line back to...
A domestic rangehood simply gets its supply from a power point in the cupboard above. A commercial rangehood would be on a designated circuit. The same wiring code covers Australia and NZ. Ignore him.
Mar 20, 2011 | Bosch DHL755BUC Kitchen Hood
How do i clean the filter out
there in no filter except for the pump trap at the bottom front behind the little door you can see. Open the door and undo the nut and remove the cover and look in and remove any items from there good luck
Jan 23, 2011 | Bosch Washing Machines
What does Fault code F-05 mean
Drain machine by running the outlet pipe into a bucket at floor level or run the outlet pipe out of the back door if it'll reach. Check the filter unit for blockages. Filter generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together with a set of heavy pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
If problem persists, check pump and pump hose. Pump removal: power off, drag machine out onto the floor, remove back cover or tip machine up at an angle, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace the pump.
Jan 20, 2011 | Indesit W 123 Front Load Washer
I need info on removing rear door panel on 2004 Grand Prix
there are Hidden Screws you have to Look Hard for Small Covers to them and Mostly there are SNAPS along the BOTTOM and SIDES Screws are Around the HANDLE and Latch
Dec 26, 2009 | 2004 Pontiac Grand Prix
Washer door will not open. washer just making humming noise
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
post further comment for more help....
Apr 17, 2009 | Maytag MAH8700A Front Load Washer
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Kitchen Ranges Logo
19 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
