Question about Kitchen Ranges
My button to turn the oven temp up or the timer does not work. Any easy fix?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on May 03, 2013
2 Suggested Answers
  • 827 Answers
SOURCE: I was wiping the front buttons, and hit self clean
you might have to run it through the entire self clean cycle.
Best regards
Ck
Posted on Jan 17, 2011
How do I set the temp so it stays in defrost longer
If its a refrigerator, there is no defrost. If its a freezer, there is a defrost termination bi metal button attached to the coil with a fixed value that will kick it back into the freeze cycle to keep it from turning into an oven in case the defrost timer fails. There is no easy way to defeat it. Sorry.
Sep 14, 2014 | Traulsen G20010 Commercial Refrigerator
How do i change the default temp?
With the oven off hold in the timer start (green) button and press the ON button. This will enter program level 1, I'm not positive which setting it the default temp but I know its like the 2nd or 3rd on the menu, one should say 375, being default temp and the other should say 525 being maximum temp, change the 375 to whatever you want and turn the oven off and back on again.
Nov 24, 2011 | Baxter OV300E Stainless Steel Electric...
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Can someone tell me where the Clean button is on a 12L proelectrix halogen oven is? All I can see is where the timer and temperature switches are!!
you dont have clean button you have turn temp down to 80 add water and wash up liquid and set timer for 5 min it tells you in manual next to hints and tips
Jan 02, 2011 | Ovens
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Oven temp doesn't stay constant
your clock/timer control board controls the oven. the switches control the top. if connects were a problem until you moved them to a certain position then replace ends. but your problem with the temp. is gonna be fixed by replacing your control board.
Jun 19, 2009 | Kenmore Ovens
Oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Sep 09, 2008 | Magic Chef CER3740 Electric Kitchen Range
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
