Question about Kodak EasyShare LS443 Digital Camera
Picture problem My Camera working properly, except one problem that is on screen no picture cannot be seen properly, only seen black picture.
  • 1 more comment
  • rsdrews Dec 09, 2007
    same problem, did a google and it seems many, many people have the same problem. If a fix is found pleae email [email protected]
  • teletubby Mar 30, 2008
    ls443, at first if zoom function used, took black screen photos. Zoom left alone, picture ok, then condition got worse, black picture all of the time, every other part of the camera is working fine.
  • Thomas Skari May 09, 2008
    My Ls 443 is giving me black screen upon clicking pics.
Yes, there are over 300 customers in china have this problem,they have accuse kodak in Shanghai China. You can view this report http://www.chinadaily.com.cn/china/2007-08/16/content_6029775.htm
Posted on Aug 17, 2007
SOURCE:
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
I turn on the camera and it is on 'Auto' for taking normal pictures, but the viewing screen is black except for my settings...I cannot see what I want to take a picture of.
Hello, you really need to tell us what model camera you are using, It is almost impossible to answer your question without more info.
Jan 06, 2013 | Kodak EasyShare One Digital Camera
Kodak easyshare m583
I have never seen a camera where the display actually contains the words 'blah blah blah' . Are you sure that you have read them correctly ?
Oct 07, 2017 | Kodak EasyShare M530 Digital Camera
What is wrong with my camera?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Nov 21, 2011 | FUJIFILM FinePix AV100 Digital Camera
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Screen and viewfinder only shows black....no picture
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 02, 2009 | Canon PowerShot S5 IS Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
