Question about cstberger 57-LM30PKG LaserMark Horizontal/Vertical Manual-Leveling Dual-Beam Ro
Lasermark lm30 the laser lens broke loose in the top what position is it supposed to be in
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
The dvd menu freezes when making selections also dvd drive makes clicking noises this player is a denon 2930ci
check the position of the reading laser lens head , it might be jerked off from its position..
see whether the dvd/cd is not scratched as this could be the reason for the freeze..
Aug 03, 2008 | Televison & Video
I just put 3 new battery's in and leaser light will not come on.
Check for green corrosion on contacts and clean them A dab of WD40 on a Q tip will may help clean & improve the connection and provide extended protection.
Aug 25, 2013 | CST/Lasermark Self-Leveling Rotary Laser...
My 1990 BMW 525i is over heating
Try replacing the thermostat. It is supposed to open when the water temp reaches a certain point usually around 180 degrees. It might be stuck in the closed position.
Sep 28, 2012 | 1990 BMW 525i
I need a manual. Power will not come on. Changed batteries. No power. Also, where does the red attachment that tells you to go up or down hook on? I have power to the unit which hooks to the pole.
Hi Richard.
The manual is available from this webpage.
http://www.cstberger.co.uk/uk/en/
Type lm30 into the text box which says "trade name/tool number" and click "start search"
Click on the thumbnail then to download the pdf.
Check for corrosion on the battery terminals and those in the laser.
From what I can see in the manual, there should be a clamp for the laser receiver that lets you clamp it to a staff.
The target plate (part 24 in the manual) has a reflective coating and there should be a magnetic holder for it.
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
Cd guide loose , it doesn't realease the cd in the right track after playing sometimes, nothing looks broke in the unit.
It came all of sudden? These symptoms are laser problem but they appear in small steps, not suddenly from one day to the other. If this is the problem check at your local electrician to change the laser lens if thereis one available for your CD Player.
Stelios.
Feb 21, 2010 | Audio Players & Recorders
Magnet issue?
No the thing on top is supposed to move. It sounds like eather a scratched disc or you need to clean the laser lens on the drive.
Jan 19, 2009 | Microsoft Xbox 360 Console
Broke x box
you have two options either a new laser lens for about £7 plus or get yourself some laser lens cleaner from £4 plus. if your not to sure on how to fit the lens then go for the laser lens cleaner
hope this helps
Jan 08, 2009 | Microsoft Xbox Console
It keeps saying there is no disk in the console or it will say system error
1) Lens is dirty
2) Game(s) disc scratched
3)cd/dvd rom broke
4) systems mainboard is broke
(stop if it works after each)
First try a can of air, or a straw and strong lungs to try and clean the dust from the top of the lens of the laser.Then try another game. Then take apart the system, and clean the lens with a q-tip and rubbing alcohol. Replace cd/dvd rom drive, ask google for directions.
Dec 01, 2008 | Video Game Consoles & Games
cstberger 57-LM30PKG LaserMark Horizontal/Vertical Manual-Leveling Dual-Beam Ro Logo
21 people viewed this question
Top cstberger Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a cstberger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
