Question about Toastmaster Coffee Makers & Espresso Machines
Can i grind flax seeds with my toastmasteeer coffee grinder model 1119
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Posted on Sep 20, 2008
  • 4 Answers
SOURCE: Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Posted on Sep 25, 2008
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
WHERE TO FIND FLAX SEED OIL LOCALY
If you know local stores or places you believe might sell it locally to you then type into Google the name of the company and flax seed oil.
With no idea of location in your question is it extremely hard to tell you any local establishments that sell flax seed oil.
The best advice I can give you with what you have asked is to purchase it online instead of locally, more often than not you will get the best prices this way.
Nov 21, 2016 | Garden
When i turn on the grinder the grinded coffee keeps going on.What should I do?
they usually keep grinding until the compartment with the grinded coffee gets full or until you turn off grinder. should turn off after compartment reaches full state.
Jun 25, 2016 | Mazzer Coffee-grinder SUPER JOLLY Electric
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
Jan 13, 2014 | Bodum Antigua 5670/5671 Electric Burr...
Are mortar and pestle better than electric grinders?
It depends on what you need to grind. Some electric coffee grinders are very good for certain seeds for example, while substances like basil come out better tasting and with a nicer color when crushed with a mortar and pastle.
Also, if you need to produce big quantities of ground substances it would probably take you a long time to do it with mortar and pestle, and using an electric grinder would help you speed up the process.
Sep 12, 2013 | Home
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Can I order 2 blades for my 1119 Toastmaster electric coffee grinder?
The grinder is available for under $20 (Amazon.com sells it for under $15). At that price it's a throwaway item and no parts are available.
Jul 20, 2011 | Toastmaster 1119 Electric Blades Grinder
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
I can't get the removalable bowl off the grinder. I think the blades are stuck.
This seems to be a widespread problem on units manufactured in 2007 and later.
Unplug the unit from the AC outlet. Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Plug it into the wall outlet and use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom; avoid making grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem.
BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Jul 29, 2008 | Cuisinart SS Grind Central, removable bowl...
Coffee Makers & Espresso Machines Logo
Top Toastmaster Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Toastmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
