Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
How do you remove the armiture from a bosch 199vsr drill
Can't remove the coils from the housing
2 Suggested Answers
  • 10 Answers
SOURCE: I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Posted on Jul 03, 2012
How to remove selector knob from bosch hammer drill gbh 2-20 s
Take a little screwdriver under the knop and jump him out BUT be carefull there is a little metal pin inside the knob that can be loose and easy lost .
And important Jump out the knop (BEFORE) you have removed the 4 screws of the black house.
Jan 09, 2016 | Bosch Drills
Bosch4100saw motor trouble
Hi. It could be a weak field. Or the rear bearing (or front one) on the armature is seizing or gone. If you remove the back part of the motor housing you can see the rear portion of the armature - look for a black burnt area around the perimeter. Regards.
Sep 09, 2013 | Bosch 4100 09 10" Worksite Table Saw...
Bosch GSB20 2RE will run perfectly through variable range if tilted over to the right. Tilt it to the left and it is as dead as a door nail.
I was going to tell you to check the power cord by the strain relief. Sounds like you got it.
Jan 16, 2013 | Drills
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
My makita cordless drill barely turns and is smoking
If it's pulling hard then gets hot enough to smoke your problem could be in either the motor or transmission. If you can, seperate the motor from the trans and try running the motor by itself. If it spins free and strong, you have a jammed transmission causing the motor to over heat. If it still labors your problem could be with the armature bearing(s), brushes, or armature windings.
Aug 19, 2012 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Hilti TE14. It rotates slowly and i'm getting a burning smell from the area around the armiture?
I would bet the armature is shot for sure and possibly the field. When an armature shorts out it usually gives off excessive sparking from the brush area. When a field fails it will usually run very slow if at all.
May 17, 2012 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
My Bosch Hammerdrill 119vsr (model060119b439) doesn't start. Pulled back to check brushes. Can't tell their condition...how do I pull the brush holder ring? Any suggestions w/b apprectiated. BY
You should be able to get the brushes out without removing the ring. Just pull the brush wire off the ring tab, hold the spring up out of the way and remove the brush. When new they should be about 1/2 inch long. If they're shorter than 1/4 inch or are too short for the spring to push them firmly down on the armature, replace them. The brush holder just slips over the end of the armature and up against the motor housing. To remove it rock it back and forth while pulling it out and it will come off. Another thing to check if you drill stopped all together is the power cord and switch. Use a volt meter to check that power is getting to and through the switch.
Apr 16, 2011 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
I was drilling and it started smelling kinda like burnt plastic. now when i pull trigger, nothing happens at all. the drill is a bosch 1194vsr hammer drill
Sounds like you need bushings do not try again till you replace then as you may damage the armiture......
there should be two plastic slotted screw caps somewhere on the drill........remove those and a bushing will pop out replace those by ordering fron tool repair shop......should cost only a few dollars
Feb 14, 2011 | Garden
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
