Question about Video Game Consoles & Games
I have a 1990 kawasaki jet ski ts ran fine til a buddy sucked up rocks now it will not pump water unless its hooked up to a hose and has pressure pushing it thru
heimlich
  • 1978 Answers
SOURCE: Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Posted on Sep 03, 2010
heimlich
  • 1978 Answers
SOURCE: sprung a hole in one of the components of my jet
If you go to babbittsonline.com you can look up your own parts on the micro fiche and get the part numbers.
SOURCE: how to remove starter motor from kawasaki ts 650
Check the manual
Posted on Jan 25, 2011
  • 4961 Answers
SOURCE: jet ski overheats
You might want to post this question in a different section. This is the computer games section.
Posted on Jun 27, 2012
  • 4961 Answers
SOURCE: owners manual for 2006 kawasaki 900 STX jet ski
Posted on Jul 10, 2012
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
On 1989 Kawasaki 650 Sx jet ski: I hooked up water to engine with in-line hose connection, turned water on and ran it. It misses at mid to high speed/rpm and sometimes runs just fine. I check plugs and...
Always keep the water pressure low, when the water coming out of the side of machine is cold you should turn down pressure. Engine on first then water, water turned off then wait 10 seconds and turn off machine. If you go out on a ride then park it for say an hour and find water in cylinders I would replace gasket. My shop time on all the J series engines is 20 minutes for head gasket.
Jul 08, 2011 | kawasaki Sport & Outdoor - Others
SPLATTERS OR FLOODS WHEN TURNING
I had a similar thing happen on a jet ski I was restoring. There was a mouse nest in the water box. Ran fine straight ahead but when you turned a corner it would block the passageway for the exhaust gases to escape the water box. The pressure builds up in the exhaust system and makes the motor shut down like it is flooded or out of gas whenever you turned a corner. Once you straighten the machine up the pressure escapes and it runs fine again. The bad news is you may have to pull the motor to get the water box out and clean it (Kawasaki). It just depends on the lay out in the hull. It may be a labor intensive fix but it can usually be done for just the cost of a couple of gaskets.
Jan 10, 2011 | Yamaha 12V Air Pump
1995 kawski jet manual jet pump not working
Either the drive shaft spline is stripped or the spline in the impeller is stripped. Remove the ride plate , unbolt and remove the jet pump and inspect the splines. Intake of rocks can cause this kind of damage.
Aug 18, 2010 | Encore Software Kawasaki Jet Ski...
Where do you read the mileage on a 1996 Kawasaki 750 sts jet ski?
I hate to tell you this but we go by hrs. the motor has ran for if theres not a hr.meter on the jet-ski you well need to istemate on how many hrs.it has ran.If you think maybe the water impeller needs to be replace,it won't hurt.better to replace then be stuck.
Jun 17, 2010 | kawasaki Full Suspension Mountain Bike Men
My ski got rocks off beach in it and now it pops like popcorn
Take off your intake grate and clean out the rocks . You may have to drop the whole pump if rocks are caught in the stator. If your impeller is bent it will greatly affect the thrust and may need to be replaced.
Jun 12, 2010 | Encore Software Kawasaki Jet Ski...
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
I have a 2004 kawasaki stx 12 f jet ski with fuel problems and bad pump how do i empty and clean tank or remove it. Is there a fuel pump rebuild kit in place of the 400.00 pump cost? There is a lot of...
There is an automitive application for this fuel pump. You have to pull the assempy out of the fuel tank then remove the pump from the bottom end of the assembly. The pump is available from most auto parts stores but I got mine from Rock Auto. Airtex e2111 Ford aspire 1994-1997 (Also some Suzuki apps) I took the 30 day warranty close out. ($66.00) It works perfect.
Mar 27, 2010 | Encore Software Kawasaki Jet Ski...
Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
May 25, 2009 | 1990 kawasaki ZXR 750
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
