Dell dx58m01 No signal available on rear, green audio jack. audio is available on front jack. cable from rear jack to amp. is Ok: tested with alternate audio source. Does this imply a failure in the dx58m01 mother board, and, if so, must it be replaced?
SOURCE: Audio Jack Problem
check any other driver installed before the current driver......
Posted on Aug 16, 2007
SOURCE: asus m2n E Sli board audio
Hi all. I've just recently upgraded my tower to a coolermaster stacker. It's a Maxi tower. Any how I've got the honor of having an Asus M2N E -SLI Motherboard, I had a lot of trouble to get the sound working, so I just removed the drivers to the CM 6501 Audio card thing....you know what I mean. So instead of using the HD audio I took the ac'97. And gues what It works on both front audio and rear audio output.
Posted on Jul 23, 2008
  • 81 Answers
SOURCE: PROBLEM WITH AUDIO DEVICE
the front port wire is not connected to the mother board.please refix it .
Posted on Jan 14, 2009
proton77
  • 1183 Answers
SOURCE: Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
Posted on Apr 08, 2009
SOURCE: I want to get a manual of GENX ASV 533 MSD+ mother
Hello, I am Mubarak, I am using the Mother Board of GENX Brand,
Now, I need Upgrad the Graphics, So now I Connect a ATI Radeon RV100 128 MB DDR AGP Card (Dual VGA Port), Already I Connect this Card, But no any Display from this card, Please Help me................
Posted on May 26, 2009
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
No sound from the rear jack from my LG e2350. I am using the vga connection as my computer is old.
Plug your headphones into the computer audio out jack (green for speakers on the back or a front port labelled headphones). The VGA cable doesn't carry audio and you do not have an audio in port for bringing that signal to the monitor.
The headphone jack is useful if you are using a video source like a Blu-ray player with an HDMI cable. Then you can listen to the audio.
I wish that I better news for you. The manual for the LG E2350 is available from LG: http://www.lg.com/us/computer-products/monitors/LG-led-monitor-E2350V-SN.jsp . Click on the Support tab and look on the right side of the page.
Dec 30, 2011 | Computers & Internet
How do I connect my Wii to my Yamaha RX-A700 receiver? I am running everything through my receiver....Is it just a matter of connecting color to color wires at rear of unit...ie AV5 input?
are you just trying to get the sound? Use a pair of audio in jacks like av5. (usually red and white inserts in jack and the color of the plug ends) if you have video switching and have hooked up a video out to your TV then you could also use a composite video connection (usually yellow insert in jack and yellow plug on wire) to send the picture to the TV. A higher signal source would be component (red,green & blue) or HDMI if your reciever has that level of signal swithing.(HDMI is audio and video in 1 cable)
Jan 20, 2011 | Yamaha RXV665BL Receiver
I want to connect my laptop to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT. Before, I had a cable VGA-HDMI,...
I want to connect my CPU to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT.
Before, I had a cable VGA-HDMI, also no signal ( analogical & diginal ).
If I buy a cable VGA ( for CPU ) and 3 jacks ( green, blue, white ) for Component IN; does-it work ??
I need some help.
Dec 23, 2010 | LG Televison & Video
Where does the Microphone plug in to the Dell Vostro200
Depending on the chassis-style of your Vostro 200 (Slim-line or Tower), you may have one or more options for installing a microphone.
See below for instructions:
A. Slim-Line Model
There are two locations on this model (by default).
Front: You have the power button, then 2 x USB ports, 1 x Headphone jack-out, and 1 x Microphone jack-in.
Rear: There is a block of six audio connectors, looking only at the bottom 3 (red, green & blue).
Red = Microphone jack-in Green = Speaker/Audio jack-out Blue = Audio jack-in
B. Tower Model
There is one location on this model (by default):
Aug 15, 2010 | Dell Vostro 200 PC Desktop
Not sure if all the wires are on my pioneer 2400f
black=grd
red=12v switched
orange=12v all the time
blue=to control of power amp or auto antenna relay control
green=front left+
green/black= front left -
green/red=rear left +
black/green=rear left -
gray=front right+
gray/black=front right -
gray/red=rear right +
black/gray=rear right -
rear out jacks on back of unit goes to ext power amp if you have
Mar 31, 2010 | Pioneer DEH-240F CD Player
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
My powered subwoofer has RCA inputs for four jacks. (two front, two rear) My CD head also has four RCA outputs (2 front and 2 rear). Is there some advantage to connecting all of these with patch cables, or...
the advantage is every time you split a pre-amp signal, the voltage, too, divides in half. Your signal (music) is going down the river at 2 volts say, and when it gets to the amplifier, it is split into 4 streams. The signal will be distorted and the amplifier will not work as efficiently. Use the Front AND rear RCAs so your amplifier uses the best possible signal - for the best possible results!
Also, if you are using 4 RCAs you get true stereo FL FR RR RL Instead of L and R
Dec 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Computers & Internet Logo
David Payne
David Payne
