Question about Kenwood KDC-MP335 CD Player
Cannot select different sources
Ive read the manual and have done what it says to do and the only sources it will go to are tuner and standby nothing else. i know it will play a CD because i put one in and it auto plays, but i cannot select CD from the source menu. Any help would be much apprisheated
There is an easy solution for this, put a cd into the stereo and then go through your sources, it will now show standby, tuner, cd.
Posted on Dec 27, 2007
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
Oct 08, 2010 | Kenwood KDC-MP205 CD Player
Im trying to connect a nintendo 64 to a Matsui HDTV but i dont know which 'source' to select or what channel to select when i choose the right source. Ive plugged in a cable which allows me to switch...
If connecting by co axial or aerial type connection then you will have to tune in a channel using either manual or automatic tuner on the TV. It would be better/simpler if you had phono or scart connections from the nintendo
Feb 14, 2010 | Nintendo 64 Console
Tv went black but still get video game picture in ok
most of the time by selecting the customer menu and going into the input or source setting you are able to select the tuner/video settings. If you can select channel or tuner setting and you still don't get video, then it might need some tuner repair.
Jul 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Aux input. Kenwood ecelon dpx-701
You have to go into the menu and turn it back on. It is in the menu under "built in aux" and just switch it to on.
Feb 27, 2009 | Kenwood Excelon DPX-701
No CD
The normal source selections for this model when the SRC button is pressed are: TUNER, CD and STANDBY.
If there is no CD inside the tray, or if it is dirty, unreadable, inverted or damaged, then the CD source option will not display at all.
If the there is a known good CD placed properly inside the tray and the CD source will still not show as a source selection, you may need to RESET the unit. The reset button is near mid bottom. This will also erase all settings, memory and tuner presets.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Kenwood KDC-3027A CD Player
I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Dec 20, 2007 | Kenwood KDC-MP235 CD Player
Kenwood KDC-MP335 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
