Question about Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda
Torque settings for Toyota 1KZ Main and big end bearing
Torque settings on a yaris 1.3 16v big ends,mains,flywheel,cylinderhead
Toyota Yaris Main and Big end Torque settings:
Tighten the main and big end bolts in sequential order and in two steps.
Main bearings. Stage 1.
22 ft lbs.
Stage 2.
44 ft lbs
Big end bearings.
Stage 1.
11 ft lbs.
Then Rotate bolt head a further by 90 degrees
Head bolt torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
Flywheel spec:
65 ft lbs
Jul 15, 2016 | 2007 Toyota Yaris
Hi i have daewoo matiz 800cc can you help me by giving me the torque settings for the big end bearing caps please
You are looking for the torque settings for big end bearings and main bearings on a daewoo matiz?
Main bearings torques on a Daewoo Matiz 800cc (1999)
Stage 1: 25-30 Nm
Stage 2: 55-60 Nm
Big End Bearingsā€¦
Mar 09, 2016 | Daewoo Cars & Trucks
What is the torque setting for main bearing and big end bearing of a Toyota Yaris 1.0 1kr 3 cylinder?
Toyota Yaris Main and Big end Torques:
Tighten the main and big end bolts in sequential order and in steps two steps.
- Main bearings. Stage 1. 30 Nm.
Stage 2. 59 Nm.
- Big end bearings. Stage 1. 15 Nm.
Rotate further by 90 degrees.
Apr 09, 2015 | 2008 Toyota Yaris
Full engine torque settings for toyota corolla 1.4 vvti 2001 model
main bearing
tighting in the following stages:
22Nm then 44 Nm then 45 degree then 45 degree
big end bearing
20 Nm then 90 degree
Apr 05, 2014 | 2001 Toyota Corolla
Hi I need the torque settings for both the cylinder head and the bottom end bearings for a 1997 Toyota Prado (3.4litre petrol). Thanks
1997 Toyota Prado 5VZ-FE
Cylinder head bolts:
Tighten the cylinder head bolts in criss cross manner inside out, in four stages as under:
Stage 1. Torque the bolts up to 17 Nm.
Stage 2. 34 Nm.
Stage 3. Rotate all the bolts 90 degrees.
Stage 4. Finally rotate all the bolts further 90 degrees.
Main Bearings:
Tighten the main bearing bolts in two stages, as under:
Stage 1. 61 Nm.
Stage 2. Rotate the bolts further 90 degrees.
Big end bearings:
Tighten the big end bolt of connecting rods in two stages as under:
Stage 1. 25 Nm.
Feb 27, 2014 | Toyota Land Cruiser Cars & Trucks
Torque specs main bearing caps ,conrod cap, head bolts,etc for 2008 Toyota 1KZ-TE
go to auto zone .com and become a member its free then u can look up the manual on any car your welcome
Feb 23, 2013 | Toyota Cars & Trucks
Need to know the torque settings for the big end shell bearing caps
if you have a rebuild kit. the specs are listed in the instructions.. if not call the parts store with engine info and they can tell you...
Feb 15, 2013 | Toyota Celica Cars & Trucks
2002 audi tt 225 bhp cranksharft torque settings
Crankshaft torque settings for 2002 Audi TT 225 BHP:
1. Main bearings: Renew bolts = Yes
2. Main bearings: Stage 1 = 65 Nm
3. Main bearings: Stage 2 = 90 degrees
4. Big end bearings: Renew bolts / nuts = Yes
5. Big end bearings: Stage 1 = 30 Nm
6. Big end bearings: Stage 2 = 90 degrees
7. Flywheel / driveplate = 60 Nm + 90 degrees (use new bolts / nuts)
8. Crankshaft pulley / damper centre bolt = 90 Nm + 90 degrees (use new bolts)
Nov 25, 2010 | Audi TT Cars & Trucks
WOULD YOU KNOW THE TORQUE SETTINGS FOR MAIN BEARING AND BIG END BEARING CAPS FOR ISUZU 4JG2 ENGINE
Mains Stage 1 83nm
Mains Stage 2 167nm
Big ends Stage 1 29nm
Big ends Stage 2 45 - 60 degrees
Hope this helps
Jul 10, 2009 | 1994 Isuzu Trooper
Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda Logo
48 people viewed this question
Top Custron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Custron Audio Player and Recorder Expert? Answer questions, earn points and help others
