Question about Refrigerators
Kenmore model 106.5702*600. Why isn't it making ice?
Not making ice
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Does not make ice or dispense water
Sending switch isn't working or the water line or filter is clogged. Ps make sure water valve is not shut off
Apr 06, 2012 | Kenmore Side by Side Refrigerator
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
The Refrigerator isn't cooling. The Freezer works fine. There is ice build-up in the drain resulting in a drip inside the refrigerator. After being thawed, it re-iced within 48 hours. The fan is...
Due to the blocked drain it sounds to me as if the vents in the ceiling of the refrig. has frozen over so no air can be circulated from the freezer into the refrig. section. This tip i wrote will show ya how to clear the drain and addation to clearing the drain the ice build up would need to be removed from the vents. Here is that tip, http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 23, 2011 | Kenmore Top Freezer Refrigerator
My ice cube maker isn't making cubes,but I still get water
hello,
In a case like that usually the problem is going to be a cooling issue, is the fresh food and freezer section both cold? it obviously takes water and freezing tempatures to make ice.
2 things to check are
1) the condenser coil under the grill below door or on back depending on model is clogged with dust and needs to be cleaned
2) the fan in the freezer isn't running circulating air into ff section and directly onto icemaker
Good luck, i hope this helps
Gene
Jul 31, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
Kenmore side by side model #59432 is making ice very slow
Is the freezer cold enough? Should be close to 10 degrees
, lift the cut off arm and let it drop to see if it will start. It may not be making the switch to continue the ice making cycle.
Aug 17, 2009 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
