Question about Husqvarna Zero Turn Mower Z5426
Husqvarna cz3815 starts easily, chugs out after a few minutes. New spark plug, air cleaner, fuel filter, and fresh gas.
SOURCE: Husqvarna LGT2654 with Briggs & Stratton Intek Engine won't start
If the fuel line is dry after the fuel pump its usally the diaphram thats stuffed does it have a fuel tap in place? is it off? also i know with nem mowers just been come over from freight the fuel filter is full of oil for the first start up as the valves need lubrication first startup... take the fuel line off from the carb just have it hanging down for a start, then crank the mower over, you should then have fuel coming out of fuel line by then... see if that helps jay QLD AUS
Posted on Feb 24, 2009
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
wadembly
  • 513 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
  • 78 Answers
SOURCE: Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Posted on Jun 30, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
Craftsman 675 series 190 cc lawn mower Wont start
Take air cleaner off. Shoot some spray carburetor cleaner in the carburetor and try to start Try this a few times to see if the engine will fire.. If it fires or starts then there is a fuel delivery problem. Could be a dirty fuel filter, bad (stale) gas, a dirty carburetor. If it does not start with the carb cleaner, check the spark plug. It may be fouled. Check for spark - take plug out of head. with the plug attached to plug wire, hold plug with a pair of insulated pliers, and touch outside of plug where the threads are to the engine, while some one pulls on the start cord. You should get a bluish spark. If you get a weak spark use a new plug and try again. There should be a bluish spark. Make sure you hold the plug against the engine making good contact. If no spark at all, could a bad magneto.
Getting back to the carburetor. If you think the gas in the tank is stale, drain it out and put fresh gas in the tank. Change the gas filter.
The arburator may be cleaned by pouring a 1/2 can of fuel system cleaner in the gas tank and spraying the spray cleaner down the carburetor throat.
Jun 03, 2014 | Garden
My John Deere riding mower is not idling right it back fires through the carburetor I change the oil and put fresh gas in it and new spark plug and still does the same thing
The problem may be a dirty carburetor. Before going thru the hassle of removing the carburetor, I suggest you get a spray can of carburetor cleaner and a bottle of fuel line / injector cleaner. Pour about 12 oz.. of the fuel line cleaner into the gas tank. Take the air filter off and spray the cleaner inside the throat of the carburetor. Let the cleaner do its job for a few seconds. Disconnect the spark plug wire from the spark plug and turn the engine over a few times. You can repeat this a few times. Start the mower and let it idle a few minutes. During normal use the fuel line cleaner will clean the carburetor. I also suggest you change the gas filter before you clean out the carburetor. Check the air cleaner, and repace if very dirty.
Jun 01, 2014 | Garden
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Wont start
Remove the spark plug and check for spark. If snappy and blue with a fresh plug gapped at 0.020", then pour a little fuel mix into the plug hole and try for start. If it pops or runs for a few seconds, then look for fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Inspect the diaphragm in the lower chamber for flexibility with no holes or cracks. Make sure the fuel is fresh and properly mixed with a modern synthetic saw oil. Be sure to shake the container thoroughly each time time just before filling the tank to prevent oil starvation. Hope this helps!
Jan 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2004 rmz 250 wont kickstart, but will push-start
Kick starting is sensitive to fresh fuel. Tank should be completely drained
May 23, 2009 | 2005 Suzuki RM-Z 250
Willnot start
Check and,or; replace your fuel filter
May 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Husqvarna Zero Turn Mower Z5426 Logo
66 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
