Question about Pioneer DEH-7300BT Car CD/ MP3 Player
M4a player will it play m4a files or anything but mp3?
My MP3 won't download music
I was having this same problem, but the solution I came up with was forehead-slappingly simple. I merely put the files on my MP3 player manually, using drag-and-drop from the itunes music file folder (not from within the program) to the device storage folders.
I can\'t say if this will work for all MP3 players (ours is a Sony walkman), as they need to be able to play m4a files. But after trying a dozen ways to get WMP to recognize the m4a, and trying to get itunes to recognize the players (including trying 3rd party addons which would have had to completely erase the player to start with)... I just figured I\'d try just drag and drop and to my surprise, it worked perfectly, absolutely no problems. I\'m listening to my itunes-purchased music on the MP3 player right now.
Mar 12, 2014 | Audio Players & Recorders
Tip
How convert m4a to mp3
So, you got an M4a file and you would like to convert it into an mp3? Or are you maybe looking for a m4a to mp3 converter?<br /> First we need to understand what an m4a file really is, before you can convert m4a to mp3. Essentially M4A is an audio file format that makes use of your stock standard MPEG4 compression codec. This is exactly the same compression that comes in the MP4 video file format, except that it doesn't contain a video track.<br /> Just looking for a converter and don't want to bother with the details? Remember, It's always wise to understand what you are working with before looking for the tools. After this article is complete you should be able to make an informed decision on exactly what tool you require, and I will also recommend a great tool for you to use.<br /> What plays M4A files?<br /> M4A files can be played with iTunes, QuickTime Player KSP Sound Player Microsoft Windows Media Player and a number of other media players.<br /> iTunes songs come in the M4A format. To play M4A files with mp3 only players you need to convert m4a to mp3 by using an M4a to mp3 converter.<br /> Be careful of getting a tool that will only convert m4a to mp3 and no other file types. Chances are you will want to make other sorts of conversions as well so it saves you a lot of time to invest it a multi purpose audio converter just in case.<br /> Therefore you should consider one <a href="http://www.musicconverter.org/">music converter</a> software that is designed to convert M4A to MP3 in a short amount of time that should also l also convert most popular video formats to MP3.<br /> Consider some of the following formats when hunting for the m4a converting tool that you need:<br /> AVI Video (*.avi), MPEG Video (*.MPEG, *.MPG, *.MP4, *.M1V, *.M2V, *.M1P), Windows Media Video(*.ASF, *.WMV, *.ASX, *.WAX, *.WM, *.MWA, *.WMD, *.WMP, *.WMX, *.WVX, *.WPL).<br /> So, now you probably wonder what tool to get? Well, I fully recommend this professional <a href="http://www.musicconverter.org/guide/m4a-to-mp3-converter.html">m4a to mp3 converter</a>.<br /> <br /> haihai123
on Nov 29, 2010 | Computers & Internet
Tip
How to Convert Protected AAC to MP3 / WMA
Apple is now promoting its AAC music pricing at 3 leyers across the board by encouraging consumer to upgrade to iTunes Plus for DRM-free, although Apple listed various advantage of music in AAC over MP3, people keep looking for "AAC to MP3 converter" to convert AAC to MP3/WMA, why?
Why Convert Protected AAC to MP3 / WMA?
(1). iTunes AAC music has two types --- DRM protected AAC (with .m4p file name); Non-DRM AAC (with .m4a file name).
(2). For Non-DRM AAC (M4A) music, most of the popular digital devices can't play them, for example, if you have iriver and want enjoy iTunes M4A music on it, sorry, no luck!
(3). For DRM protected AAC (M4P) songs, only Apple's ipod, iPhone are authorized to play them, of course, with limited number of iPod players and computers to which to transfer.
(4). MP3 and WMA are the most popular audio formats for most of the digital players including PSP, PS3, Zune, Xbox 360, creative Zen, Archos, Iriver, Blackberry, Samsung, Sonywalkman, HTC, Sansa, Cowon etc.
Converting protected AAC to MP3/WMA needs a all-round application that can remove DRM and convert AAC to MP3 both.
Why Choose DRM Music Converter to convert Protected AAC to MP3 / WMA?
DRM Music Converter can:
(1). Remove DRM from online stores like iTunes, Zune Marketplace, Napster, Rhapsody etc.
(2). Support input audio formats: protected AAC (M4P), protected WMA, M4A, MP3, AC3, OGG, APE, WAV, MKA.
video formats: M4V (protected MP4), protected WMV, protected ASF.
(3). Support output audio formats: WMA, M4A, MP3, AC3, OGG, APE, WAV, MKA.
Then you can:
(1). Convert AAC to MP3, WMA, M4A, AC3, OGG, APE, WAV, MKA;
Convert AAC (M4A) music to MP3, WMA, AC3, OGG, APE, WAV, MKA;
Convert protected WMA to MP3, M4A, WMA, AC3, OGG, APE, WAV, MKA;
Convert protected M4V / WMV / ASF video to MP3, M4A, WMA, AC3, OGG, APE, WAV, MKA.
(2). Transfer iTunes music on non-Apple AAC-compatible digital players; Play protected WMA at will.
(3). Play and share music in whatever format on whatever player you l
How to Convert Protected AAC to MP3 / WMA?
1. Free download Aimersoft Music Converter and run it, then add your protected files:
2. Settings for converting AAC to MP3:
3. When go through the first 2 steps, hit 'start' button lower-righted on the main window, converting AAC to MP3 will be soon done, then you can freely enjoy or share iTunes AAC music on your digital palyers!
on Jul 28, 2010 | Computers & Internet
Cannot transfer MPEG-4 (.m4a) files
Hello, friend, you may convert the m4a file to mp3 file for a try, I know GOGEAR RAGA MP3 Player supports mp3 well. If you don't know how to do that, this audio converter will help you a lot.
http://www.freedvdripper.net/audio-converter.html
Hope it helps. Contact me if you have any other question.
May 27, 2013 | Philips 4GB GoGear RaGa MP3 Player
I can't play my music
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable.
For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 27, 2013 | Audio Players & Recorders
Eclipse cld2 player won't play with headphones, says no files, but when pluged into computer file shows up on laptop and will play through media player? Why can't player find files downloaded on it? ...
This mp3 player is only compatible with mp3 files. If you can play the songs with your media player, chances are that you have the wrong file format for your player. WMA and m4A file formats are not compatible.
To convert your audio files, use the free program found at this location. http://download.cnet.com/Koyote-Free-Mp3-Wma-Converter/3000-2140_4-10442362.html
Remove the incompatible files from your mp3 player.
Import the mp3 files into your media player, then transfer them to your MP3 player.
Mar 07, 2011 | Eclipse CLD2 MP3 Player
What happens if my files are mp4
You will need to convert your mp4 files to mp3 for them to play in the Sansa M250. You can download a free converter at:
http://www.maniactools.com/soft/m4a-to-mp3-converter/index.shtml
Oct 19, 2010 | SanDisk Sansa m250 MP3 Player
The player doesnt read i tune files
The other mp3 player can't support itunes file except iPod.so if you want to play itunes music in all MP3 and Digital Media Players,you need a special program to help strip off the protection and convert the itunes m4p, m4b, m4a music to mp3. i always use wondershare music converter. my friend introduced it to me. it can convert the songs from iTunes at very high speed.
please read this article
http://answers.yahoo.com/question/index;_ylt=AuDrGn.STnPw8pqUIclJiTXty6IX;_ylv=3?qid=20100111184001AAYi5aH&show=7
Jan 16, 2010 | Audio Players & Recorders
How do I delete M4a (Itunes) podcasts from my mp3 player?
Since this player is not MAC compatible - even though you can get SOME things to work, you are going to have a hard time getting those songs off there. How did they get loaded there in the first place? You will have to connect the GoGear to a Windows PC - may require reformatting, since it was last formatted as a MAC player (only if you have problems, though). And delete the songs using a PC.
Jun 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Pioneer DEH-7300BT Car CD/ MP3 Player Logo
18 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
