Question about Refrigerators
Lcs27925 ice maker not level
Samsung refrigerator ice maker
Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Blue icecube maker
Clean or replace water level probe.
Jun 14, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
There is ice in the ice tray but will not dump
da7a4823-cd31-448f-bac2-11ff8c3d6b4e.jpgCan you confirm your refrigerators model number? If youre model is the KSCS25INSS there can be two possibilites. The Electronic Ice Level Control Board or the ice maker itself=> 2198597 Ice Maker Assembly Instructions on how to diagnose the ice maker and the Ice Maker Level Control can be found HERE I am here if you have questions, Thanks Sea Breeze
Oct 04, 2013 | KitchenAid Superba Architect KSCS25INSS...
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
My ice maker keeps dripping water at the front by the control module
Make sure your refrigerator is level. Once your refriderator is level you should also check that your ice maker is level. You have some range of movement of the screws that attach the ice maker to the refrigerator if you loosen the screw and push up on the ice maker then re-tighten the screw.
Jul 20, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
HOW DO YOU REPLACE THE ICE MAKER IN A AMANA REFRIGERATOR MODEL NUMBER SZD25NL. I UNDERSTAND THE REPLACEMENT ICE MAKER PART NUMBER IS AP4135008 MADE BY WHIRLPOOL. IS THIS CORRECT? THE ICE MAKER THAT IS...
You may not need an ice maker. See if it is level. If the ice maker is overflowing with water there is an adjusting screw to lower the water level.
Jan 29, 2011 | Refrigerators
When is ice maker activated ;with bar up or down ??
The bar will sense ice cube level in the holding bin. If it is all the way down it will tell the ice maker to make more ice. When the maker "dumps" the ice the bar should be all the way up and will lower to check the level.
Jan 02, 2011 | Kenmore Refrigerators
Ice maker makes large chunks of ice about half and other half of ice is normal ice cubes
check you Ice maker is it level...if level I would check the water level you may be getting to much water in to it...
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Need less water to the icemaker when it fills ice maker it uses to much water
Hi: I don't know how much you mean by to much water, but that model uses a simple ice maker. If it's just a little water over flowing; Put a level on it and make sure the ref and ice maker are sitting level. If too far out of level the ice maker will leak water. Try this before calling service. I hope this helps, Jeff
Jun 09, 2009 | Kenmore Elite 44723SS Commercial...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
