Ricoh Aficio C2050 error SC865-01
I have not turned this machine on in 6 months, it has been in my home office(climate control present. I turn it on today and it has this error. Is there a way to rebuild the drive thru the service mode? It also has a flashing message it the lower right that says "Problem with Document Server (Utility)"
SOURCE: Ricoh Aficio 1232C copier
thats a fuser code you can reset it by hitting "clear all button" then type 107 and hold the stop button to get into service once in chose the copy option on the display and scroll to 5 mode once in choose 810 and you'll see what to do after that.
Posted on Oct 06, 2007
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Posted on Dec 17, 2008
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
I have an error on my gestetner mp c2030 with code sc222, please help me.
Problem with the yellow laser unit. Probably need a tech for that one.
May 20, 2014 | Ricoh Compatible 4 Color Set Aficio MP...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
Ricoh Aficio 250
Turn the machine off and turn it back on. Usually the code is reset.
Possible charge corona wire error.
Does
Jun 19, 2008 | Ricoh Aficio 250 Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Open Questions:
1,992 people viewed this question
k24674
