SOURCE: Trying to change drive belt on cub cadet ltx 1045.
What i use is a SMALL pipe wrench to fasten between the big pulley and little pulleyand let it jam against the front crossbar that the spindles are attatched to or equivalent
then you can remove that bolt with a 6 point socket shallow or deep well
comes out ccw and is torqued back to 55 ft.lbs.
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
SOURCE: drive belt diagram for a cub cadet ltx 1040
Go to this website, upper right hand corner and do a parts look up.
Search for your model and that good stuff they ask of you and then
choose mower housing should be there, browse the site it's really cool
and has a lot of info.
http://www.jackssmallengines.com
I did a
sample search for generic riding mower deck and found great diagram of
belt routing. Give it a try jelly bean you will find same results Good Luck! Don't forget the thumbs!
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
