Question about Quickie Wheelchairs Parts Breezy Ultra 4 Light Weight Wheelchair Quickie
Wheel nut fell off
My husbands wheelchair has lost a nut and the whole wheel has come off, we have gone to several stores but no one has a flat, M16 1.0 pitch nut, which is what we were told we need. Can you help me find one?
    Scholar:
  • 61 Answers
Since you already know what kind of nut you need, go to the local bolt supply house and get a nut. I would think you could also order the parts online for the chair.
Posted on May 11, 2015
How do I remove wheel Lock nut on 1999 Isuzu Trooper if lock key has lost?
we cant see it of the 100s made.
go to any tire./wheel store and ask them to fix this.
or drill yours out. (some you can, no photo no joy here)
Aug 17, 2014 | 1999 Isuzu Trooper
I have several wheelchairs in which one of the wheels stops touching the floor and just spin while the occupant is moving and trying to turn.
Depending upon manufacturer, the chair wheel height must be set up as per the manual otherwise wheels will spin.
Aug 05, 2014 | Health & Beauty
Has clicking noise on right pull wheel
Clicking noises from the drive wheel area usually means the gearbox on that side has a minor to a more severe issue. Call the place where you got the chair. I'm glad it's running and it could continue to run even with the clicking noise. It could be something as a loose hub nut on the wheel or something rubbing when you are making a turn.
Dec 23, 2013 | Electric Jazzy 1115 Power Wheelchair
Slightly wobblyLarge Wheel
Properly inflate tire and make sure wheel retaining nut on shaft has not come loose.
Jun 07, 2013 | Medline Travel Folding Transport Wheel...
My husband ran over the back wheel on my daughter's pretty in pink bike. where can I get a new back wheel for this bike?
Any bike shop and some of the smaller town hardware stores. All you need is the size to find a replacement. You can probably find one that will work nicely at a thrift store for about 10 bucks. You will get the whole bike but you can just salvage the wheel.
Jan 23, 2013 | Next Pretty in pink
Right wheel fell off how do I put it back together need a schematic
if your wheel fell off there is no shematic that i know of however check to see if the studs are stripped if so pull the wheel ( POP-OFF THE BEARING CAP WITH A FLATHEAD SCREWDRIVER) unscrew thew wheel nut and pull the wheel (being careful not to drop the bearings on the ground ) then with an old nut or board (2 by 4) or something similar so you don't flare the stud so that it wont go through the hole. drive studs out and replace (fairly cheap). when you put the new studs in make sure that the teeth on the back of the hub line up with the teeth on the studs before you drive them in.if the whole fell off make sure that the threads on the spline (shaft) are not damaged. if so repair the threads and get new bearings . ( bearings only go in one way) and nut and cotter pin. (if you don't know that the race is any good take the hub to the auto parts store and ask the attendant at the counter) when reassembling do not over tighten the wheel nut and BE SURE TO PUT THE COTTER PIN IN AND BEND 1 PRONG BACK.
Sep 08, 2010 | 1987 Ford Ranger
Hi, I have a flat rear wheel. I must remove the wheel to repair it. I've removed the central locknut, but the wheel does not come out. There seems to be something else that must be done to remove the...
wd-40 and a rubber mallet tap around the wheel so not to bind one side, or you may have to take it to a dealer with a wheel puller, PS do not lose the key that holds the axle to the wheel
Apr 21, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Wheel nut on wheelchair fell off.
Sure, you can buy on your near wheel chair distributors.
Nov 22, 2008 | Health & Beauty
1996 ford f250 4 wheel drive truck
Item Part Number Description 1 N800794-S60 Bolt, M16-2.0 x 50 2 N601797-S2 Bolt, Caliper Mount M12-1.75 x 30 3 2C150 Pin Assembly 4 2C357 Disc Brake Caliper 5 1175 Seal 6 3423 Bearing 7 3105 Front Wheel Spindle 8 4221 Differential Bearing 9 4222 Differential Bearing Cup 10 1190 Wheel Seal 11 1102 Front Disc Brake Hub and Rotor 12 1102 Front Disc Brake Hub and Rotor 13 1197 Locknut 14 1B198 Lockwasher 15 1C245 Thrust Washer 16 35704 Dana Nut 17 2K004 Front Disc Brake Rotor Shield 18 2B292 Anchor Bracket 19 3130,
Jun 11, 2008 | 1996 Ford F250 Crew Cab
Quickie Wheelchairs Parts Breezy Ultra 4 Light Weight Wheelchair Quickie Logo
301 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
