Question about Car Audio & Video
How to fix my Kenwood kac 5272 it won't play any music but the fan is running
2 Suggested Answers
  • 9 Answers
SOURCE: KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Posted on Jun 24, 2010
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
My kenwood excelon KAC-X811D overheats after about 15 minutes and my fan won't turn on, i'm thinking either that or the ground wire being to small could be part of the problem. id really like to know how...
Hi was the fan running fine before overheating problems if so sounds like the fan has gone open amp up take fan out and take to a elec store for replacement
Oct 18, 2009 | Kenwood Excelon KAC-X811D Car Audio...
My kac-910 keeps shuting off at high volumes after about ten minuets i have two 12s
loose ground? shortage? overheat? sounds to me personally that problem with subs or wire touching ground...so signaling for asmp to enter protect mode?
Jun 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kac-ps201t problem
I had a similar problem with a KAC-X812D Kenwood amplifier.
My problem turned out to be that the RCA inputs were so sensitive, they picked up interference from my head unit through the RCAs.
I replaced the head unit with a newer model, and had no problems after.
This may not be your case, but hope it helps.
Dec 15, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp light turning off and on
if you see that happen you might need to your i c sound chip or your trasistor change then and check
Dec 11, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood Excelon KAC-X812D mono amp
Right next to the rca inputs you will see a reset switch, Reset the amplifier by holding that switch in for about 20 to 30 seconds. This amp has a microprocessor in it that controls the fan. The LCD display that you played with only shows the status of the fan, it does not control the fan. the fan should turn on when the amp starts to get hot. It operates at high or low or stop. If the fan never comes on, even when the amp is very hot, you will need to take it in to be serviced. There is no easy fix to some of the problems. You need the fan to work, so check it out soon and determain if the fan ever comes on. It may take a while to come on, but if it comes on after it starts getting hot, it is working.
Jun 17, 2008 | Kenwood eXcelon KAC-X812D Car Audio...
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
