Question about Samsung LW15M13C 15 in. LCD Television
Samsung LW15M13C LCD Television
Audio is ok on normal terestrial tv, but when connected via scart or L & R audio in the audio is seriously low. I have tried different input devices but the problem remains. Maybe an internal amplier problem? Trouble is that I can't seem to get any schematics for the unit. I am used to working with surface mount devices as I work in mobile phones as an R&D technician. Any help would be gratefully received
SOURCE:
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
VOTIT
  • 2071 Answers
SOURCE: Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
SOURCE: I have just bought a
hi,i have just bought the ue40c5100 led tv and i have returned it twice and am now on my third one the problem is when i watch a bluray movie if the movie is wide screen like most movies are u will see a slight glow of light from the top left corner,the two previous tv's i have had done it in every corner but this only does it at the top left,thankyou for your time hope u can help me.
Posted on Feb 02, 2011
Audio out level low
Is there a "audio out fixed/variable" in sound menu? If there is, this would output 'line level audio' vs. variable level by TV volume control.
May 08, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Hi. I have Philips HTS3115 connected to the TV Philips 37PFL9603D/10 via HDMI cable. Everything works fine with DVD and CD player. Just with the option "TV" there is no sound from TV in the...
"In the past I have got the old flat TV connected with SCART"... what about the present? HOW is the "TV" audio connected to it?
My advice would be to remove the TV as a sound source and get the TV-audio from the audio outputs of wherever it really originates. In most cases that is a Cable Box which can be treated like a high-end audio device for this discussion.
Ever wonder why Cable Boxes have separate audio and video outputs and TV's have multiple inputs? So you can send the BEST version of audio and video directly to the BEST electronics that NEEDS it and NOT to or through anything that adds nothing to the quality. Heck, many TV's are monitors without audio at all. THAT is how I would treat any TV for serious high end listening. Send the digital Cable Audio to the soud system and the 'regular' RCA audio to the TV for low-fi TV-watching like news and Oprah.
Jun 19, 2011 | Philips HTS3115 Theater System
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
LG Plasma 42PC56 optical digital audio out
I can't imagine your setup. Box, tv and pc speakers?
Typical setup would be box, tv and some kind audio system with optical IN. Correct wiring would be connect box to tv via scart and connect optical cable from BOX to audio system. You have to go from box not from TV since scart connection doesn't carry audio signal. To have TV to output optical audio out you would have to connect it to box via hdmi.
Dec 02, 2017 | Televison & Video
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LW15M13C 15 in. LCD Television Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
