Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
EX-Z60 A Casio
When powering up the lens comes out and back in and reads retry power on. I do it again and it reads lens error. I took a suggestion off a website to go into the menu and disable the rec on mode. By doing this I now cannot bring my pictures up to view them. Thank you in advance for any advice given. Kman
  • 3 more comments
  • gingerlinne Aug 09, 2007
    Unfortunately no beeping. The lens comes out and back in again in one full sweep. No disturbing or unnatural noises. What will I be looking for if I take the lens out? Thanks in advance for any reply.Gingerlinne
  • gingerlinne Aug 27, 2007
    Am I going in the right direction on trying to get the camera to stay on though?
  • gingerlinne Aug 29, 2007
    Well its like I said with my first post. The lens comes out all the way and goes back in again. Just like it always has when it powers up. Mind you that no strange noise or different sounds. The power does not stay on. That is why I was wondering if the lens is the right way to go with this problem. Getting the camera to stay on is the real issue. I was just disrcibing the fact that everything seems to be operating correctly up to the point that the power should stay on. I hope this helps. Thanks for any replies on this.
  • gingerlinne Aug 30, 2007
    Yes, Thats it exactly. Sorry for not realizing that you did understand my problem. Once I get to the gears, is there an adjustment to be made to fix this problem, Or will I be looking for something that is hanging up the gears?
    Your quik responce is greatly appreciated. I will let you know how it goes. My office is closed Friday and Monday so you should get some feed back Tuesday. Once again, thank you.
  • 34 Answers
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Posted on Aug 09, 2007
  • 2 more comments
  • jayfixit Aug 27, 2007
    You'll be looking for a place where the focus motor gears, or zoom lens gears get hung up. It's probably the focus motor gears, which are the tiny gears which can be seen behind the metal backing plate on the rear of the lens. Some of them are visible after removing the CCD which is held on by two screws. Then, the back plate will have to be removed on the lens assembly to get to all the focus motor gears.
  • jayfixit Aug 28, 2007
    I guess I don't understand the "trying to get the camera to stay on" comment? If the lens is already partially extended, and the camera can't get it to go thru it's "initiallization" sequence, a lot of times it won't let you do anything. You can try using the "play" button instead of the power, or camera button if you want to see your pictures. But that doesn't always work either with a bad lens.
  • jayfixit Aug 30, 2007
    Ahh, ok, I understand. Yes, the problem is the lens, which is why it goes back in, and then says Turn Power Off and On Again. The lens has sensors that tell it the position it "should" be in when it powers up. It sounds like the zoom lens is working ok, as it extends out ok, but the internal focusing lens most likely is not. Therefore, the camera shuts down, and tells you to "try again".
    You'll want to remove the lens assembly. It's held in by two little spring tabs at about 5 and 10 o'clock. Then, remove the rear silver backing plate. You'll see 3 tiny gears. This is for the focus lens. The focus lens moves up and down a brass screw. Make sure this moves. If it doesn't it's either hung up on the screw, or there is a tiny piece of sand/dirt in one of the focus motor gears.
That suggestion help me. Thank you 'jayfixit', The only clarification I would add is that the silver backing you refer to is held by 4 black screws around the outer rim. Not the one in the center with two silver screws that I found out later held the CCD chip.
Posted on Oct 07, 2007
SOURCE:
Casio exilim ex-z60 lens error retry power
the same thing happened to me &nd i took it apart &nd nothing happened .
Jul 12, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
When I try to turn the camera on, shows message "retry power on"
hola no tengo driver de la camara como puedo vajarlos largan chameleon
Jul 06, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Jan 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Can't take pictures
Casio Tech Support - especially if it is a young camera But repairs are not an economic option.
Jun 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Dec 14, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
211 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
