Question about Furniture
EMS.9 Get-A-Way Massage Chair by HWE
Stops working after 1 min... rollers will nto work. Can it be fixed??
5 Suggested Answers
  • 11800 Answers
SOURCE: My EMS 9 massage chair
The massaging is done by small motors with eccentric weights attached to the shafts. Those motors are controlled thru a very simple control board that in your case appears to have failed.
To fix the chair you will have to access the board and find out why it has failed - at least a basic experience in electronics is required, to perform the tests on the relays and triacs used to control the motors. If you don't posses this experience then all you can do is to check that the power cable, the remote cable and the motors cables that plug in the board are firmly inserted - for everything else you will have to call a pro.
Posted on Sep 14, 2011
  • 17 Answers
SOURCE: What is the difference between a Swedish massage chair and a Shiatsu massage chair?
A Swedish massage chair incorporates five different stroke patterns (sliding, kneading, tapping, vibration and friction) across muscles groups; while a Shiatsu massage chair combines pressing, swaying, patting and rolling movements while targeting pressure points.
Posted on Aug 06, 2012
  • 41 Answers
SOURCE: How much weight can an electric massage chair handle? I am overweight and want to buy a massage chair; however I would hate to spend the money and in the end damage the chair or void the warranty.
Each manufacturer has their own weight limit published, so I advise asking in advance. From my research, it seems that most chairs can hold up to 270lbs; although there are some models that have a higher capacity.
  • 5 Answers
SOURCE: Can I use an electric massage chair when I'm pregnant?
There is no overt problem with using a massage chair when pregnant. If you are comfortable then use it. You and the baby will be fine. If you'd like to read more about massage chairs and pregnancy, check out this article...
http://www.massage-chair-relief.com/blog/general/can-massage-chairs-be-used-when-pregnant/
Hope this helps!
Posted on Aug 08, 2012
Trying to locate a distributor/repair person who has a MH194V-0 (2 1/2" x 3") circuit board for a human touch EMS-12 massage chair
3ways you can get this information
1-- go to a retailer of the chair and find out where it can be repaired --that will get you an authorized service agent
2-- call the manufacturer direct for a list of authorized service agents
3--- go google and type in-- manufacturer of ems 12 massage chair-- and click on the distributor / service agents tab and call them direct on the phone
Nov 14, 2016 | Furniture
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jul 17, 2015 | Proform Crosswalk Advanced 525x Front...
How do I fix this problem on Elna 6003 which stops working after about 1 min and the computer say stopped for safety.
Hi Gary, I'm Julie. It sounds as though your motor is heating up and then cutting out. Something to try. Clean the machine following the instructions in the user manual. Ensure that the bobbin area is clean. If the motor continues to cut out take your machine to a service centre. One or more parts may need replacing.
Good luck. Kind regards, Julie
Mar 26, 2015 | Elna Sewing Machines
Where can i find a part for my chair, ems.6 get away chair
how is it connected to where is pops off does it need a new roller or bearing , I do not know anything about these chairs but if you look at it good and try to work it while watching it and see what makes it come off then you can pinpoint your problem ant take it from there you can prob fabricate something if you cannot fine the right part, good luck , post some Pics so I can see what is exactly happing ,
Nov 25, 2014 | Vacuums
After refilling the printer is not printing more than one page at a time
the paper feed rollers/ seperation rollersare the most likely cause- the machine will make three attempts at feeding from the cassette before throwing a jam light . open the paper tray and completely removethe feed tray which then gives you clear access to the feed roller ( black about 1 1/2" long) positioned about 2" into the cavity on the top.#
clean this roller (slowly turn roller to get at all sides) with wd40 Spray (on cloth) allow 5 mins for the cleaning fluids to do their job and then completlely wipe off any oil from the roller - given another ten ,minute to air the feed roller should now work again at least for a little bit - You can order a maintenance kit which contains this roller and also the seperation pad ( found on the cassette ) as well as a new fixing unit .which will most likely fix the fault good luck
Jan 29, 2014 | HP LaserJet 2420dn Printer
I have a interactive health massage chair model ems-9-s. when you turn the power switch on the back rollers run for 10 seconds or so and it stops. The power light is on in the controller but nothing will...
Hope it is still under warranty. Need new board and possibly more. My parents bought a similar chair and it failed with many issues to fix. Tech replaced all the electronics. Good luck.
Nov 27, 2013 | Interactive Health Ijoy 130 Human Touch...
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Furniture Logo
81 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
