I have a coleman evcon forced air heater i get beeping noise from the deluxe blend air
The beeping alarm on the auto deluxe blend air II doesnt work
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
  • 252 Answers
SOURCE: coleman evcon air unit keeps blowing the three amp fuse
BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU! That said, it sounds like you have a short in the control (24VAC) curcuit to the condenser. A mouse probably made a home in the control compartment of your condenser. BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU!
Posted on Apr 26, 2009
SOURCE: Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Posted on May 10, 2009
Coleman evcon model DGAT070BDF
Open hi temp limit switch or fan limit bad
Apr 01, 2014 | Coleman Propane Forced Air Heater...
Coleman evcon electrical furnace doesnt force air intermittently
It sounds like the fan is not functioning. With the breaker, SSU, and/or power off check the wiring, tighten any loose wiring, and make sure nothing is blocking the fan from spinning. Check to see if it will spin by hand, if there is access. If it does, and you have power, then the fan motor may need to be replaced.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Nov 30, 2013 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Coleman Evcon furnace, blower runs continuously even after the temp has been reached.
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
Dec 16, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
