Lonbt12 Bluetooth Can't connect bluetooth
SOURCE: jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Posted on Oct 23, 2008
kozachek
  • 122 Answers
SOURCE: I need to connect my H371 bluetooth but dont have
The default pin for a bluetooth headset is 0000
Posted on Mar 22, 2010
  • 87 Answers
SOURCE: does not connect to bluetooth
you need factory reset. dial *#7370# and proceed by pressing YES.
before reseting it is recomended that backup all your valuable datas such as contacts,notes etc
Posted on May 11, 2010
  • 67 Answers
SOURCE: I use this code'*#9990 in my nokia 3110c mobile
Hi, your problem is need to reprogram your cellphone or try this also maual reformat to your cellphone just dial this *#7780# and default password nokia 12345.but before you that reformat you need to back-up your files to memory card and save your contacts to sim memory.after you that the cellphone is back to normal setting .i wish that i help your problem.thanks
Posted on Jul 23, 2011
Not sure how to connect phone to hilux bluetooth
The option for pairing bluetooth with phone is available in thephone's settings. Enable bluetooth under settings, and ensure that the bluetooth device is set to 'discoverable' or 'pairing' mode. Simply scan for devices from the iPhone via the bluetooth settings.
Nov 30, 2011 | Sony Ericsson Cell Phones
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
I cant connect xtm-1200 bluetooth device to my system
Ok, so you've successfully 'paired' your Bluetooth Headset with your computer. Now we're going to 'connect' the Headset so that you can start using it. There are two ways in which we can 'connect' our Headset. Both of the methods I'm about to tell you about achieve the same thing so really it's up to you how you want to do it.
Method 1: Note: The first time you try the following method, your Bluetooth Headset may not be visible in the context menu we're about to bring up. 'Right-click' the Bluetooth icon in your Windows taskbar and highlight 'Quick Connect'.
Note: If you're unable to select 'Quick Connect', it's likely that you're Bluetooth Adapter isn't switched on so you should firstly, 'right-click' the Bluetooth Icon and select 'Start the Bluetooth Device'.
Jul 29, 2011 | Computers & Internet
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
May 10, 2011 | Acer Aspire 5742Z-4200 Notebook
Jaguar x type bluetooth
If your car has the Bluetooth phone option fitted (most models with the touch screen 2006 onwards do) You may get the message SIG instead of Phone connected.
Please see http://www.blujag.co.uk for detailed bluetooth instructions.
Jul 16, 2010 | 2005 Jaguar X-Type
How to activate bluetooth on dell vostro 1700
turn on the bluetooth using the wireless switch located on the left part of the computer. make sure it is on the 1 position not on 0
Feb 19, 2010 | Dell Vostro 1700 Notebook
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
How to start bluetooth in my lenovo laptop?
i haven't any bluetooth confuguration in my laptop so what can i do ?
Apr 06, 2009 | Lenovo 3000 N100 Notebook
 Grubhead
Grubhead
