From address is not registered
How can i obtain fax confirmation
The station name comes up I would like the number to come up instead, it seems to show the option for either, is there a way to change what comes up.
  1. Obtain the printer's TCP/IP address.
  2. Open your web browser.
  3. In the URL field, type http://MFP's IP_ADDRESS, where IP_ADDRESS is the TCP/IP address of the printer.
  4. Click on SETTINGS.
  5. Click on FAX SETTINGS.
  6. Click on ANALOG FAX SETUP.
  7. Scroll down to FAX LOG SETTINGS
  8. Change the LOGS DISPLAY to DIALED NUMBER
Nov 09, 2012 | Lexmark X342N Multifunction Printer -...
Why i can't open facebook account
You need to have a valid email address. Facebook will confirm if the the email address you registered with is an existing one. If you do not have a functional email address, register one and retry opening a facebook account.
Aug 27, 2011 | Facebook Social Network
I have registered my Brother MFC 9840CDW on the brother website but it still says "not registered" when I try to email a scanned document. I registered it online. Do I have to do anything on the...
If the LCD shows Not Registered when you enter a One-Touch or a Speed-Dial number, it means that an email or number is not stored there.
If you selected E-Mail and save the E-mail address, you can only use the E-mail address when you are in Scan mode. If you selected IFAX and save the E-mail address, you can only use the E-mail address when you are in Fax mode.
Your machine has 20 One-Touch keys where you can store 40 fax or telephone numbers or E-mail addresses for automatic dialing. To access numbers 21 to 40, hold down Shift as you press the One-Touch key
You can dial in any of the following ways.
Manual dialing
Use the dial pad to enter all the digits of the telephone or fax number.
One-touch dialing
Press the One-Touch key that stores the number you want to call. (See Storing one-touch dial numbers on page 60.)
To dial One-Touch numbers 21 to 40, hold down Shift as you press the One-Touch key.
Speed-dialing
Hold down Shift as you press Search/Speed Dial, and then enter the three-digit Speed-Dial number. (See Storing speed-dial numbers on page 61.) Three-digit number
May 17, 2011 | Brother MFC-9840CDW Laser Printer
How do i clear the fax address book?
If not used as network printer you can use Initialize All Data to remove all settings.Initialize=ERASE>>> WARNING>>> this will remove all settings for header,number,user boxes,network settings. Unless you print all of these other settings for fax - network(Additional Funtions Report) and remember how to re-input DO NOT USE THIS.
You can have a fax tied to a one-touch button and that will prevent you from deleting from the fax screen.
1st>Send tab>reg.tab>Register One-Touch Button>Highlight Name>Erase tab will activate touch Erase>Yes to confirm
2nd>Send tab>Address Book>Register>RegisterAddress>Highlight Name>Erase>Yes to confirm
Apr 27, 2010 | Canon imageRUNNER 4570 Copier
Unable to find activation number for Photoshop CS2
I can offer you my experience with activation of Adobe CS3 - Student Edition purchased in Australia in March 2008. Perhaps it will help.
The product included a document marked with a 'coupon code' and instructions to obtain the serial number (activation number) by forwarding evidence of eligibility for the student edition by fax or email to Adobe. (A similar 'proof of purchase' may apply for standard editions).
However, both the fax number and email address pre-printed in the documentation were obsolete. I was ultimately able to obtain the activation code via email from Adobe but only after some investigation to obtain the correct email address. In the South Pacific region this address is (or at least was, in 2008): pacificservice@adobesupport.com .
Perhaps they can direct you to the correct email address for your region.
Mar 05, 2010 | Adobe Photoshop CS2 for PC
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Confirmation Page
Function 74 set 12 set 2 set stop.
Aug 27, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Faxing from memory
I am not sure exactly what you are trying to do. Here is the internal Kyocera link for the user guide and fax quick list. Hope this helps they are down loadable PDF's.
http://www.kyoceramita.eu/content/sites/kme/eu/en/index/service/dlc.html?initial=false&search=any&searchTerm=FS-1118&category=#
Jan 05, 2008 | Kyocera KM-F650 Plain Paper Laser Fax
How do i add a name/number to the phonebook memory?
I think that do the following and if it doesn't work let me know and I will be able to obtain a manual from work and give you detailed instructions.
Press Menu
Move to register quick dial
press enter/select/start
then register
Follow the on screen instruction.
When you come to enter the name of your contact use the number pad as you would when SMS text on your mobile phone.
Thanks J
Dec 04, 2007 | Samsung SF-340 Plain Paper Inkjet Fax
43 people viewed this question
jasbo
jasbo
