Question about Hayward 1 Hp 2 Speed Super Pump Inground Pool Pump ( Ssp2607 102 ) ()
Sta rite pump
Hi i have a sta rite pump for pool its a 5p2rd-1b i think a 0.75 hp and its really noisy, ive taken off the wet end and turning the impeller by hand its not smooth and feels like bearings gone. how can i get them replaced? many thanks ian
    Top Expert:
  • Hayward Master
  • 4,292 Answers
No bearings available need new motor
Posted on Mar 05, 2016
  • 11 Answers
SOURCE: noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Posted on Feb 17, 2009
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
  • 136 Answers
SOURCE: I have a hayward 2hp pool pump motor that hums but
your starter capastor has gone bad or got diconnected it`s look`s like round cylender 2 inch by 4 inch dimention`s or it could be an internal (inside the motor) depending how new the motor is
Posted on Nov 06, 2009
Testimonial: "Thank you very much for your help"
john224
  • 1378 Answers
SOURCE: I have a Hayward Sp2607x10 Super 1 Hp Swimming
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings and a 201 seal. All told, depending on the labor rates, it should be less than $75.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 08, 2010
Testimonial: "Excellent...changed the bearings and replaced the front seal and all is well...thank you so much!"
  • 990 Answers
SOURCE: I have a Hayward Max-Flo II pool pump and it is
Sounds like the bearings but uou would need to take it to a motor shop to have this done. This will cost less than the spectility tools needed to do the work.
Posted on Mar 29, 2010
What is a Sta-Rite Max-E-Pro Pool Pump impeller
take off silver band clamp that will separate the motor from the wet end remove the plastic piece on the side with the motor impeller is inside check to see if glogged use a stiff piece of wire to clean out
Aug 08, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
The inpuller broke and i can't get the old one out
Remmove the back of the motor. You will see there are flats on the armature for you to grab with a 7/16 open end wrench. The impeller can now be removed with pliers or by hand.
Thanks for your interest in FixYa.com
Sep 24, 2011 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
My2 hp max e pro pump runs but barely moves any water
Have you opened up the wet end? If you have pine trees near you, it is probably a blocked impeller and needs to be cleaned. If this is not the case, is the pump basket full of water or air?
If it is full of water, it is either the impeller, or the motor bearing.
if it is full of air, it is an o-ring or shaft seal. more likely the shaft seal. Always check the impeller first.
Oct 09, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
My sta rite pool pump turbine is turning slowly and i think i need to clean out debris from the turbine, how do i do this ?
With the power off, you can remove the basket and reach inside the hole behind it into the pump body. Use a screwdriver and needlenose plier to do this. If you can feel the clog. (It will be soft and spongy) work it counter clockwise to loosten it from the impeller. Then pull it out with the plier. Hope this helps, good luck.
Apr 30, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Hayward 1 Hp 2 Speed Super Pump  Inground Pool Pump ( Ssp2607 102   ) () Logo
47 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
