Question about Timex Ironman 53151 Wrist Watch
Watch isn't recognised by computer
The watch woin't wake me up at the set time.
    Genius:
  • 1,157 Answers
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
I want to change only date
Try This
  1. If your screen is dim, tap the screen to wake up the watch.
  2. Swipe down from the top of the screen.
  3. Tap Settings System Date & time. If you don't see Settings right away, swipe left.
  4. Tap Automatic date & time.
Looking for smart watches with low prices Customized Mobile Covers Phone Cases Smart Watch Designer Watches
May 26, 2018 | Watches
How do set Casio model 6054 gw1000b
On the Casio website, this model 6054 isn't recognised. With the module number (you'll find it in a small rectangle on the back of the watch case) you can download the manual for your watch here:
Timepieces Watches Manuals CASIO
Mar 07, 2015 | Casio Pathfinder Watches
My Eco drive watch acts as if the Daylight Savivgs feature is not workig properly, I set the time turn the feature on all is good, wake up the next morning and it's an exzactly 1hour behind, I check t
The time on these watches has to be first properly referenced to UTC. I do not have the instruction book for your watch or even have a clue to the model number since you did not put any model number. There are several dozen Eco Drive models in each of the Citizen and Casio, and other type watches that are solar powered.
I have several types of Sky Hawk watches in the Citizen, and similar ones in the Casio. Check your instruction manual about how to set the UTC time, and how to set the offset time for your location. Once properly set up your watch should stay on time. If you have the radio receiver in your watch for the auto time setting, once the watch is set up properly it will maintain proper time all the time.
Feb 10, 2018 | Watches
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Mar 12, 2014 | Maxi Aids Shake n Wake ZZZ Vibrating Alarm...
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
The watch has an alarm that goes off at 10:17 pm, 12:00 am, 12:05 am, 12:10 am, 12:15 am, 12:20 am, 12:25 am, and 12:30 am. It wakes up the entire house. I don't know how to turn this alarm feature off. It...
Go to the casio web site "www.casio.com/support"
select "manuals"
Select "watches"
Select "watch manuals archives"
Enter details of you watch and download instructions.
Jan 06, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Winding and setting the time on a rolex watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Apr 04, 2009 | Rolex Watches
Setting the alarm of my casio watch.
Visit this site:
http://world.casio.com/wat/download/en/manual/
Enter the right numbers from the caseback and download manual for your watch.
Don't forget to rate, please.
Jan 14, 2009 | Casio AW80-1AV Wrist Watch
Timex Ironman 53151 Wrist Watch Logo
233 people viewed this question
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
