Question about Ryobi Garden
Throttle torsion spring
I have a Ryobi BC30 brush cutter and can not figure out how to put the torsion spring back in the throttle trigger assy. HELP
  • 246 Answers
SOURCE: r\r the pull rope spring assy
Hello:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
The Following is a "General" "Chainsaw Clutch Removal" File. **To Hold the Crankshaft for Removal of the Clutch; Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
Mike258
  • 1498 Answers
SOURCE: i have a ryobi brush cutter rbc 40sb the pull
Hi there
A chainsaw or small engine repair shop may have the part.
If not, Click here for the Ryobi Service center locator page. Just enter your zip or area code and it will display a list of the nearest Ryobi service centers.
Hope you find this very helpful
Best regards
Mike
Posted on Nov 24, 2009
SOURCE: arbor stuck on gear head/bc26
I have the same problem. Any solution?
Posted on May 01, 2010
  • 27 Answers
SOURCE: how to put recoil spring
The recoil housing is held on by four screws around the housing on the corners, the pulley is held to the housing by one screw, all tension needs to relieved from the spring before removing the pulley. you can either cut the rope if you are replacing it, or you can pull some of the rope out, lining up the notch in the pulley with the outlet hole, catch the pulley and hold it from rewinding, and using the slack in the rope pull a section back in and up through the notch, the pulley can now unwind its tension without winding up the rope. Now remove the pulley, it should leave the spring in the housing. If the spring is very rusty it should be replaced, if you've sprung the spring out and have a mess, be prepared for a little fight, you can try hooking the outside of the spring in its tab in the housing and while forcibly holding that in place begin coiling the spring back in place, or try gathering the spring into a large coil and holding the coil with a pair of pliers begin shrinking the coil's diameter by winding it up from the center, last resort and the one I'd recommend if you're looking at a rusty spring, get a new one from an Echo dealer, it comes pre-wound and a nifty retaining clip, it simply slides into place in the housing, and as it goes into place the ring will pop loose. Now for the rope. Install the rope by putting the new piece in the spool and tying it off, thread the other end through the housing from the inside out, and put it into the handle and tie it off on that end, now place the spool into the housing being sure to engage the spring lightly, now install the screw so the spool doesn't come out, pull the slack rope up through the notch in the pulley and begin winding the pulley in the direction it turns when the rope is normally extended, after about 4 turns drop the rope out of the notch and let the pulley wind up the rope, if you have slack repeat a couple turns until there is no slack
Posted on Jul 04, 2010
rycgl
  • 1545 Answers
SOURCE: Can't figure out how to remove "arbor" so I can
I just found out that the string head adaptor (arbor?) has left-handed threads...so try loosening it the other way. Here it is:
http://www.ereplacementparts.com/ryobi-bc30-ry30004-brushcutter-parts-c-7931_15654_15655.html
Posted on Aug 14, 2010
I have a ryobi x 430 string trimmer. The timing belt came off as mentioned in other postings and I put it back on according to online tips. It ran well for a while. Now, it is hard to start, but it...
It is possible that the timing gear jumped a tooth. Take off valve cover and check to make sure timing marks line up. Other than that check other things like carb adjustment, good gas, air filter and other general tune up things.
Aug 27, 2013 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
The pull start cable is jammed on our Ryobi brush cutter mocelRBC-320E how can we fix it. Thankl you
Going to have to pull it apart down to the cable and see what is jamming it but be careful cause the coil spring in the may come out usuall just been pulled to hard and stuck
Jan 24, 2011 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to adjust....et voila....
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
My Ryobi router is not working at all. It spins
It can be any number of things that cause this:
1. Broken power cord
2. Failed on off switch
3. Failed trigger switch
4, Brush or brush tube assy failure (Most common failures)
5. Open armature winding
6. Open field winding
If you can not get continuity across the power cord with the switch on and trigger switch depressed yhe only option for further troubleshooting is to open the unit.
You can go to this page then click on go to power tools store and under model number use R161
http://www.ryobitools.com/support/parts_batteries
The manual lists all 50 parts in your unit.
Item 16: Brush assy part # 968304-026
Feb 04, 2010 | Ryobi ROUTER KIT P163K
I have Ryobi BC30, that will not recoil. How can I fix this. I took the shaft off, then undid the screws that hold the plastic (gray) housing, but I still cannot get to the cord. How do I get in there?
You have to remove the motor from the housing. To do that, you remove the part that connects to the drive cable. Take a #15 TORX screwdriver and put it in where the cable would go. That will allow you to remove the part. Then you will see the clutch. It spins off counterclockwise. You'll have to figure how to hold the shaft while spinning off the clutch. Once the clutch if off, you can remove the motor and starting pulley. You may find the spring has broken. Get a new one and be CAREFUL putting it back in. Once the spring is in, reassemble the rest of the trimmer...Good luck...
Aug 25, 2009 | Ryobi Garden
I have no spark on my bc30 trimmer. I have changed the sparkplug but still no spark
You probably have a bad ignition module (coil).Or, you have a wire from the kill switch grounding the plug.
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
21 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
