Question about Kenmore Washing Machines
Mod.110.28012011 out of cycle sequence
Why does all my lights flash in sequence on my Tricity Bendix washing machine
That actually looks like a normal system self test procedure the machine runs through in order to check everything is ok before the cycle commences. If however the machine was to stop part way through a cycle and display a sequence of different lights that sequence would indicate to the repairer what the computer determined to be the fault.
Oct 08, 2012 | Washing Machines
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
Blower motor doesnt always come on in heat mode
Yes if your creful. There is a sequencer inthe unit that operates the fan in the heat mode. It sometime sticks. This is due the moisture from the ac sweating. You van pick upa sequencer at HVAC parts house. Just wire back wire to wire and you willbe ok. Kill power to furnace first. Rus
Dec 03, 2009 | Refrigerators
My maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Nov 25, 2009 | Maytag Washing Machines
Whirlpool mod#LLR6144AQO electrical issue
If you have power at the console where the power cord connector connects to the harness then make sure all wire harness connections to the timer are tight. If so, then something must have happened to the timer as nothing else will keep the machine dead in fill and spin.
Nov 30, 2008 | Whirlpool Washing Machines
Blinking light on start button and no action!
Call a technician from the place you purchased it. It should still be under warranty. If not by them, then I would try the manufacturer. Warranty Job
Dec 04, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
I need solution for those questions
Here are the answers:
1. Use the MOD operator
DECLARE @i AS INT; SET @i = 0
WHILE true BEGIN
SET @i = @i + 1
IF @i % 10 BEGIN -- This is the MOD operator
UPDATE table SET Fields FROM table WHERE clause
END
END
% This is the MOD operator to find the remainder, which when @i is divisible by 10, the remainder (MODULAS) is 0.
2. You can't. Only the first and last can be defined. Any other AFTER triggers besides the first and last will fire in undetermined order.
Please rate FixYa! ThankYa! Happy db'ing.
Dec 04, 2007 | Microsoft SQL Server 2000 Standard Edition...
Kitchenaid not cycling
DONT KNOW THIS UNIT BUT TRACE BACK YOUR STEPS. CHECK THE PRESSURE SWITCH FOR AN AIR BUBBLE AS THERE SHOULD BE NO ACTION WITH THE ROTORS UNTILL YOUR WATER LEVEL IS CORRECT.CHECK IF THE SUMP LIMIT ISNT STICKING.
Aug 22, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Washing Machines Logo
65 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
