Question about Garden
Craftsman 42 inch LTS 2000 will not move forward or go into reverse. What could be w
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for Craftsman LT 2000 42
Look under the "running boards" Sears(AYP) sometimes put them under there. If not, go to www3.sears.com, type in your 917.xxxxxx model number and the pictures will show you an exploded view of the belt configurations
Posted on Sep 14, 2009
wadembly
  • 475 Answers
SOURCE: craftsman 42 inch belt diagram
look on deck or under foot pedal there is usually a diagram in those places
Posted on Jun 27, 2010
My 2009 Craftsman 42 inch cut will go good in reverse but barely go forward??help!!
Make sure your tires are inflated
ensure the front of the mowing deck isn't dragging on the ground.
check the drive belt that powers the transmission.
May 21, 2017 | Craftsman Garden
Husqvarna 42 inch cut with hydrfostatic ****** will barely move in forward or reverse
check the belt tension also if it sounds like a growling sound check the fluid level
Aug 20, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
TIGHTEN BELT ON A LTS 2000 RIDING TRACKTOR
A) Which belt? There are at least two.
B) If it is a Craftsman ( there is no model number posted) then all the belts' tension is maintained by springs. There is no adjustments.
C) The service model number is located on a label under the seat.
Nov 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lost my manual on my Craftsman LTS 2000 20 HP-wondering if I can mulch leaves with my lawnmower and how?
They make a mulch cover for the discharge chute and a good set of mulcher blades. You need the 9 digit model number from the label under the seat and you can get them from sears
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Transmission running eratic sometimes will only move in reverse. I have to move lever forward and back several time to get it to move forward.
You can try an air purge 1st. Instructions for this can be found in your owners manual. If that doesn't help the trans-axle will need replacing.
Oct 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
