Question about Coleman Mach 15 Air Conditioner
What is a compatible replacement for the coleman a/c 48204A876?
What is a compatible replacement for the 15K coleman a/c 48204A876? THE UNIT IS A FEW YEARS OLD, AND I AM LOOKING TO REPLACE IT WITH ANOTHER 15K COLEMAN A/C
motor1258
  • 6674 Answers
SOURCE: Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Posted on Aug 16, 2008
co7196
  • 3433 Answers
SOURCE: coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
Posted on May 18, 2009
  • 127 Answers
SOURCE: Coleman roof top rv air no cool,warm compressor
No Cooling.
Turn the selector switch to “Cool” and the
thermostat to a low temperature (below room temperature).
The fan runs OK, but the unit does not cool. When the unit
housing is removed, we observe that the compressor does not
run; however, it periodically hums for 15 to 30 seconds.
Possible Causes- Check all of this before buying a new unit, that may not be the solution.
“The voltage could be low – ”
a) Check the voltage between #1 on the
overload switch and the “R” terminal of the
compressor while it is not humming. This
voltage must be 115 volts domestic USA
models or 240 volts export/overseas models.
No less than minus 10% is allowable.
b) Check the voltage from “C” or “R” of the
compressor while it is humming (trying to
start). The latter reading will probably be
lower, but it still must be 103.5 volts
minimum domestic USA or 216 volts
minimum export/overseas models.
If the first reading is above 103.5V domestic USA and
the second is under 103.5V domestic USA, there is
too much voltage drop in the lines - a situation which
must be corrected for the air conditioner to perform
safely and satisfactorily.
2. “A capacitor could be shorted, weak or open.”
Turn the power off.
Caution – There is always a chance that a capacitor is
holding a residual charge, so before touching a
terminal, discharge the capacitor as explained earlier
in this booklet.
Remove capacitors, visually examine them and test
them per instructions given in earlier section on
capacitor testing (See page 9).
If the capacitors test OK, replace them and carefully
reconnect the wires. Be sure the wires are connected
to the right terminals.
3. “Start relay contacts could be open – ” if so equipped.
Turn off all power, then check for continuity with
ohm meter between terminals 1 & 2.
4. “Compressor start winding could be open or
grounded.”
Check compressor windings per instructions. See the
section on the compressors (See page 8).
5. “Compressor could be mechanically stuck.”
This very rarely occurs and when it does, it is usually
after a lengthy shutdown. This should be considered
only after all the above possible causes have been
positively eliminated. To free a stuck compressor, use
your hermetic analyzer according to the
manufacturers instructions.
Posted on Jun 29, 2009
icemelts
  • 246 Answers
SOURCE: Coleman 3 ton ac unit should condenser fan push or
condenser fans typically 'pull' air (from around the unit) across the 'hot condenser coil' - and discharges it away from the unit.
Posted on May 06, 2010
motor1258
  • 6674 Answers
SOURCE: My Coleman rv mach3 63134cst which is about 3
If coils are clean, or have been cleaned recently, then check your discharge side of unit for restriction. It may require you to take down ceiling assy, to be sure that there is nothing blocking the duct work inlets, if it is a ducted system. Also if ducted system, make sure you don't have too many blocked/shut off. As well you should have a freeze probe, or round sensor in the coils at front where intake filter goes over, (evaporator) to sense the frost, and kick compressor out until it thaws. When was the last time the evaporator and condenser (rear) coils were cleaned?
Posted on May 16, 2010
I need a battery charger by coleman or one that is compatible with a coleman workmate cordless drill.
check for the power specs which is in the sticker label attach to the unit
Feb 07, 2016 | Drills
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
Aug 20, 2015 | Coleman Heating & Cooling
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
Can you get a replacement Evcon PN 7956-319 board or simular?
Please see link below:
http://www.northamericahvac.com/servlet/the-2287/Coleman-Gas-Furnace-Control/Detail
OR
http://www.climatedoctors.com/items/item.aspx?itemid=6802187
I have confirmed from a number of sites that the 7956-319 and 7956-319P boards are compatible.
Good luck.
Apr 06, 2010 | Tools & Hardware - Others
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
71 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
