Started with loud humming then one day went to metal grinding and loss of power. The smell was awful. Now no reverse.
Do I need to replace whole rear end or just certain parts?
Thanks !!
Is the rearend blown into peices? if yes replace the whole thing. If not put it in reverse and have someone look to see if the rear driveshaft is spinning. If it is you more than likely need a ring and pinion set in the rearend. If it doesn't spin the problem is in your transmission not the rearend.
Yes I was.
Thanks, we will check it out. Hopefully its not the whole rear end or the transmission !!
Were you driving when this happened?
