Question about Craftsman Garden
917 386620 Won't stay started longer than a few seconds.
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: lawn boy starts for few seconds then stops.
Hi johnnatale20...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jul 17, 2011
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
Car cranks but won't Start
It sounds like your alternator mat have gotten wet. there is usually some sort of cover under the alt. I would get that and the battery tested. They can be tested while still on the car. If it won`t start you would have to get them pulled and checked. Usually free of charge.
Nov 12, 2012 | 2001 Audi TT
Won't stay running. starts but then dies within a few seconds
clearly sounds like fuel starvation, I would be looking at the throttle body, they need servicing every couple of years, they fill up with like grease and block tick over hole.....
Mar 06, 2018 | 1991 Mitsubishi Montero
Bogging
Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
Dec 29, 2011 | 2000 Pontiac Grand Am GT
Mower will start but won't stay running as it cuts off in a few seconds
how do i replace the primer bulb on my yard machine thanks 21 in cut 6.50hp 190cc
Oct 01, 2011 | Toro Lawn Mower With Toro Power Tools
2001 Yukon SLT, engine will not turn over - friends think it's the alternator. Battery is 2 yrs old. My friend tried to jump start it, that did nothing, still won't stay turned on. I got the...
Hi there !
I won't say its an alternator problem because the alternator only charges the battery when its on, And it should start with the jump cables even if the battery and the alternator are bad. your Issue is not clear. Does the car start when you jump it ?
Aug 15, 2011 | 2001 GMC Yukon Denali
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
