Question about JVC SP-PW100 Subwoofer
JVC Surround Sound System
When we are watching a movie and the surround sound volume is above 45 and a climactic moment arises in the movie (music gets loud all of a sudden), the whole surround sound system shuts off. All you hear is a click and it's off. Then we have to turn it back on and the volume setting is set to the 30's (I've seen it as low as 32 and as high as 39). What could be causing this? The only power we lose is the surround sound system. It's like it's blowing a fuse or something and then resets when we turn it back on. Please help!! Thanks!
  • ztmdad Nov 06, 2007
    Same problem if volume is above 40 then Subwoofer shuts off and you have to shut the system off to get any volume back.,
  • JVC Master
  • 5,554 Answers
The click will be a relay to protect the main amp overloading. In many ways you are driving the amp to hard, unless there is a fault on the main amp which means it can't take the full load that it should handle. One cause of this for example would be a speaker that is either the wrong ohms, or of a lower wattage than what the amp can put out. Or in some cases a faulty speaker, or if the wiring is not good shorts when the speaker shakes when a very loud noise comes from it.
Things to check:
1 That no speaker is lower ohms than the amp.
2 That no speaker is lower in watts (RMS) than the amps total output for that channel it is on. Remember not all surround amps have the same volume on each channel.
It is of course possible to use smaller wattage speakers. But if you have an amp that can output say 200w. Connecting an 80w speaker to it would really limit the amount the volume control could be raised to.
3 Each speaker is working right. Plus all connections are neat with NO possibility of shorting.
If all of these are good then you have a fault on the main power amp. Probably one or more of the output device(s)
Posted on May 09, 2017
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
When watching a DVD in surround sound movie mode
FIRST- double check that the center channel is hooked up in the center channel connection. we have all made this mistake. second if you are watching a movie through a dvd or bluray player be sure that both your audio L/R rca's or hdmi cable's are plugged in. I do not know if your are on cable or satellite? Double check the connections. Be sure that the that if your can select your sound preference turn it to 5.1 surround or matrix. hope this helps
Jan 11, 2010 | LG LH-T754 Theater System
Loses sound during loud moment in movie or if sound is above 30.
Check the speaker maybe one are about to get fried
Jul 03, 2009 | JVC TH-C5 System
Rear Speakers dont work
THe rear speakers are usually for the surround sound experience. What kind of movies do you watch? Usually the action movies have a lot of surround sound, calm movies not so much. And for the music, the same thing applies. Atleast for my system.
Hope this helps.
May 09, 2009 | Televison & Video
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Onkyo HT-SR800 the surround speakers are not blasting
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Sep 14, 2008 | Onkyo HT-SR800 System
Technics
are you trying to use the surround sound for movies or music ? , ive got the dvd version of this system (sc-dv290) and ive noticed the surround sound tends not to perform well with music , but sounds great with movies. i think its because the movies have dolby digital and music does not. The dolby pro logic in my opinion doesnt really make that much of a difference in sound unless the sound is cranked up past 44db on the amplifier. the only cables you need are the ones that are attached to the surround sound speakers and they cannot be removed so it cant be the wiring . I reckon you have a 1 - faulty system 2 - listening to music 3 - maybe not pressing the pro logic button on the sound processor. Hope this helps
Sep 11, 2008 | Technics SC-DV290 System
JVC SP-PW100 Subwoofer Logo
6,117 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
