Question about NorStar BCM 3.6 BCM200 BASE SYS 16 DIGTL STATION MCDN BDL
How do i find the ip address for my BCM 200 - NorStar BCM 3.6 BCM200 BASE SYS 16 DIGTL STATION MCDN BDL
Server unreachable
go to menu --> settings --> network configuration --> server menu and scroll down to server address and give the server ip address and save the settings and reboot
Mar 26, 2010 | Nortel i2004 IP Phone
Please help can u please tell me the ip address for a zhone router
IP Address for the Router is 192.168.1.254
connect the Zhone router to the Computer with ethernet cable
Click start - run - type cmd or command
in the Black DOS Screen - type ipconfig press Enter
it will provide you with IP Address (i.e Default gateway address)
Jan 08, 2010 | Zhone (6218-I2-200) Router
Can not access the router
Check the ip address on the computer.if your computer is not connected to the router then connect the computer to the router and try to open the setup.
when you check the ip address, you will see the default gateway number that is the ip address of the router.
click Here to know more about how to open the setup of router
Oct 29, 2009 | Zhone (6218-I2-200) Router
I want to use the e studio 200 as a printer
the reason the printer button dont work can be several things have you got the printer boards and snanner board fitted if so hte reason it cant connect is you also need fthe gateway address .. this is the ip of the router..the signal for printing has to pass through this to and from the computer to the network card in the copier..
Aug 02, 2009 | Toshiba Estudio 200L Copier
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
Dns failed when i tried to setup xbox live. i have a belkin router set up and my console is set up next to the xbox. what do i need to do?
Information on setting up port forwarding can be found at:
http://portforward.com/
If you want to go with a static setting this is what you need to do:
  • Login to the Router/Gateway by entering it's IP address in your web browser. (http://192.168.2.1)
  • On the left panel of the firmware page, under "Firewall," you should see a link "DMZ" for the Static IP configuration.
  • Your router should generate 25-50 Dynamic IP addresses for, choose a Static IP outside that range. (192.168.x.200)
  • Then go into your Xbox network configuration and set the IP address to the newly defined DMZ.
  • IP: 192.168.x.200 Subnet: 255.255.255.0 Gateway: 192.168.2.1 (Primary DNS is the same as the gateway)
If you need more information about your router follow this link:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Mar 08, 2009 | Microsoft Xbox Console
Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
Routing
show ip int brief This will show you the available interfaces and type.If you want to create on Fa0/0 for example the config will be as follows:
On configuration mode type
Interface fa0/0.[vlan Id]
encapsulation isl | dot1q [Vlan id]
Assuming you are using dot1q and terminating vlan 200 The config is as follows
int fa0/0.200
encapsulation dot1q 200
ip address --------
on Gig Port
Int gi0/0.200
ip address
The encapsulation used should match the switch trunk.Default encapsulation is isl on cisco switch.If you are connecting another vendor use dot1q encapsulation.
Dec 27, 2007 | Cisco 2501 Router
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
Jun 20, 2007 | D-Link NetDefend DFL-200 Firewall
Computers & Internet Logo
66 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
Alun Cox
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
