Question about Task Force Garden
My task force pressure washer's soap does not come out How do I get it to work
3 Suggested Answers
Devious1969
  • 76 Answers
SOURCE: I NEED A OWNER MANUAL FOR TASK FORCE PRESSURE
Try this:
http://www.taskforcepowerwasher.com/pdf/TF2500_Manual_Rev0.pdf
Posted on Sep 07, 2010
SOURCE: Can' get the soap to go in my pressure washer
I dont know about your system but you probably have dirt in your suction valve venturi or injector valve.
Posted on Aug 28, 2012
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Oct 04, 2014 | Garden
Can i get a manual for this not syre i have all the parts grandpa passed and trying to hook up
www.pressurewashersdirect.com/manuals/CH%20electric%20manual_2.p..
www.ppe-pressure-washer-parts.com/task-force-power-washer-parts
Jul 02, 2014 | Task Force 2000 PSI Electric Pressure...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Can't get soap to mix with sprayer of Honda gc190 Power Washer.
    they only pull the soap out with the low pressure nozzles
    Sep 02, 2012 | Garden
    Aug 28, 2012 | Craftsman Garden
    How to get soap to come out of dispenser of mcculloch power washer fhh 18a
    Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
    Jun 17, 2012 | McCulloch Garden
    It will not **** in cleaner soap
    Your heading is for chain saws but going by your problem I'll assume you are having problems with your pressure washer. The most likely reason your washer won't draw the soap into the water stream is you are using one of the high pressure tips, usually red, white or yellow. The only way the soap system will work is if you use the low pressure, soap tip which is black. Another thing to check is the soap line and pickup filter to make sure they are clear and allow the solution to be picked up.
    Apr 14, 2011 | Garden
    John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
    The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
    May 18, 2010 | Dewalt 3800 PSI Pressure Washer
    Garden Logo
    41 people viewed this question
    Top Task Force Garden Experts
    Tom Chichester
    Bill Boyd
    Are you a Task Force Garden Expert? Answer questions, earn points and help others
