Question about Roland VersaCAMM VP-540i
Roland versacamm vp 540
While printing an image, in the white areas, it is printing a rainbow of colors. What is a good solution?
2 Suggested Answers
  • 9 Answers
SOURCE: I have a Roland Versacamm
this sounds like a scan motor error. clean encoding strip and test. If still wavy remove scan sensor the one that reads the encoder strip, clean with alcohol, replace and test. if still bad replace encoder strip and the eye that reads it.
Posted on Jun 26, 2011
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
My roland vp-540 will start printing and then when busy printing it will just stop, if you go into your versawork on computer it just says not connected? What could be the problem?
Just one Question?
Do you have your LAN Cable tied with your AC power Cable?
I have th same problem on two VP540 after seven years of trouble free working. A few months ago I was reorganizing my shop and I tied up both cables to avoid tangle cables with machine wheels every time I move It.
I think that the noise produced by AC Voltage Affect the VP540 ethernet port.
Aug 14, 2012 | Roland VersaCAMM VP-540i
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
I have a Roland Versacamm and as it's printing an image that is supposed to be a rectangle shape 40"x60"...as it prints out the image is not straight it actually looks wavey like a flag? The printer was OK...
Aug 02, 2008 | Roland Vs-2000CD Digital Studio...
Roland VersaCAMM VP-540i Logo
21 people viewed this question
Top Roland Office Equipment & Supplies Experts
Chas Peters
Level 1 Expert
Michael Harrier
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
